V Carved Headstocks http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=53655 |
Author: | 6string [ Sat Nov 07, 2020 11:47 am ] |
Post subject: | V Carved Headstocks |
These were carved for 3 special young lady’s ( my niece’s ) using a Millright Carve King, and V carve software. |
Author: | meddlingfool [ Sat Nov 07, 2020 2:43 pm ] |
Post subject: | Re: V Carved Headstocks |
Neat! |
Author: | ballbanjos [ Sat Nov 07, 2020 4:49 pm ] |
V Carve is a nice program (I guess a niece program in your case--sorry, couldn't help myself...). You did a fine job with it on the headstocks! Dave |
Author: | J De Rocher [ Sat Nov 07, 2020 5:06 pm ] |
Cool! |
Author: | SteveSmith [ Sat Nov 07, 2020 10:07 pm ] |
Those are perfect for your young ladies! |
Author: | banjopicks [ Sun Nov 08, 2020 4:56 am ] |
Now that's a first for me. Not sure how I feel about it. |
Author: | Mark Mc [ Sun Nov 08, 2020 5:57 am ] |
Looks great! A really lovely idea. So this looks like a very special triple necked guitar - they are going to have fun playing together. |
Author: | Clay S. [ Sun Nov 08, 2020 7:52 am ] |
Very nice! Will you leave them as is, or fill in the leaves and flowers with color? |
Author: | jfmckenna [ Sun Nov 08, 2020 11:35 am ] |
That looks awesome! What is V-Carve? |
Author: | 6string [ Sun Nov 08, 2020 11:45 am ] |
Mark Mc wrote: Looks great! A really lovely idea. So this looks like a very special triple necked guitar - they are going to have fun playing together. No it’s not a triple neck guitar. These are individual necks, not bolted to the bodies yet. |
Author: | Ruby50 [ Sun Nov 08, 2020 2:50 pm ] |
How will they be finished? Ed M |
Author: | bcombs510 [ Sun Nov 08, 2020 7:51 pm ] |
They look great, love how the flowers are unique for each. Did you carve just the headplate and then attach to the neck? It sort of looks like the tuner holes and bushing holes were also done on the CNC? Or maybe you used the fancy bushing framers from SM after the headplate was on? John, V-Carve is design and control software for CNC. I only know this because I’ve recently started working with it. ![]() Brad Sent from my iPhone using Tapatalk Pro |
Author: | 6string [ Sun Nov 08, 2020 11:15 pm ] |
bcombs510 wrote: They look great, love how the flowers are unique for each. Did you carve just the headplate and then attach to the neck? It sort of looks like the tuner holes and bushing holes were also done on the CNC? Or maybe you used the fancy bushing framers from SM after the headplate was on? John, V-Carve is design and control software for CNC. I only know this because I’ve recently started working with it. ![]() Brad Sent from my iPhone using Tapatalk Pro Carved the plate oversized 1/8 all around, then glued to the headstock and trimmed. Headstock was already profiled with holes drilled. Tuner holes, and washer recesses on plate were cut on cnc at the same time as carving. Used 10 mm bolts to line up plate to the headstock. |
Author: | Ed Haney [ Mon Nov 09, 2020 11:33 pm ] |
Are automated machine carving and automated machine routing the same thing? |
Author: | 6string [ Tue Nov 10, 2020 11:21 pm ] |
Ed Haney wrote: Are automated machine carving and automated machine routing the same thing? I guess sort of. A router or spindle head is used with a CNC machine to hold router bits to do the work. In V carving a v bit, usually 90, 45, or 22.5 degrees is used depending on detail needed etc. I used all three sizes of bits to carve these. When v carving the router moves in all 3 axis. X, Y, and Z. Or in other words left to right, forward to back and up and down. The Z axis ( up and down) is what basically separates v carving from any other. As the carved portion requires a narrower cut the head moves up, wider it moves down. This is all controlled using G code co ordinates created by whatever software you wanna use. I use Vectric v carve software. If you just want to just cut profile shapes it will do that also. |
