It is currently Fri Sep 19, 2025 3:02 am
 Post subject: Cutaway bend too tight?
PostPosted: Tue Jan 22, 2019 2:01 pm
First name: Raul
Last Name: Ortiz
Hi guys, getting ready to build my first cutaway. Second guessing my cutaway, too tight?? I got some really nice Ziricote, just a bit nervous about bending this. I'll be using a Fox style bender with a heating pad.
What do you guys think, does it look ok to you?Image
Sent from my R1 HD using Tapatalk
PostPosted: Tue Jan 22, 2019 2:26 pm
I think it will be fine.
These users thanked the author Chris Pile for the post: guitarradTJ (Tue Jan 22, 2019 3:38 pm)
PostPosted: Tue Jan 22, 2019 2:34 pm
Likewise...though I'd also be a bit wary of ziricote...
These users thanked the author meddlingfool for the post: guitarradTJ (Tue Jan 22, 2019 2:54 pm)
PostPosted: Tue Jan 22, 2019 2:55 pm
First name: Raul
Last Name: Ortiz
That's my main concern... I've never worked with Ziricote, haven't heard great things about it's bending...
PostPosted: Tue Jan 22, 2019 4:40 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
That should be doable. If it was me, I would thin the section through the horn more than the rest of the side to make it easier to bend. Don't overdo it though because if the side ripples there during the bending, it can make it hard to level sand it afterwards without sanding it too thin or going through. I would also pre-treat the wood with Supersoft veneer softener. I've only built one guitar with ziricote but it bent fine. That guitar didn't have bends quite as tight as that, but I think it would have worked if it did based on how the wood behaved during bending on my hot pipe.
These users thanked the author J De Rocher for the post: guitarradTJ (Wed Jan 23, 2019 2:27 pm)
PostPosted: Tue Jan 22, 2019 5:16 pm
First name: Larry
Last Name: Hawes
Might be OK, can you test it on some scrap? And not to be critical but does it have to be that tight?
I was just looking at some Lowden pics this morning and their cutaway looks lovely and not too tight either. I'll try and design similar for my first cutaway..
https://themusicemporium.com/guitars/ac ... rer/lowden
If the line from the waist to the cutaway were just slightly more rounded, instead of what appears to be straight, it might ease the cutaway tightness just a bit.
Thank You and Best To All
These users thanked the author LarryH for the post: guitarradTJ (Wed Jan 23, 2019 2:27 pm)
PostPosted: Thu Jan 24, 2019 7:43 am
Its doable, and doable by hand. That being said, its one that will take patience and experience. One trick is to use a metal strap and clamp it on either end of a bend. As you bend the strap holds in place and its tension on the outside of the bend increases helping to prevent cracks. GO SLOW. Be sure to mark the start of the cutaway so you don't end up with it in the wrong place. When the tight bend is done you can switch to a different strap with handles on the end (LMI used to sell one) and bend the recurve toward the block. If you get grain lifting. STOP. Glue it down with CA using UHMW cauls. Let it cure by itself and come back and try again.
These users thanked the author dberkowitz for the post: guitarradTJ (Fri Jan 25, 2019 4:39 pm)
PostPosted: Fri Jan 25, 2019 4:39 pm
First name: Raul
Last Name: Ortiz
Those are some beauties!!
I'm doing my best to compromise on my radius, I really like the look. I'll definitely try some scrap first.
PostPosted: Fri Jan 25, 2019 4:41 pm
First name: Raul
Last Name: Ortiz
Great info, thanks! I'll be using the bender, as I'm eager to try it out. I like the strap idea. And definitely will be going slow and get some extra patience going that day!
PostPosted: Fri Jan 25, 2019 5:01 pm
Last Name: Beaver
City: Lake Forest
If that is your first cutaway I would do a trial with some scrap wood before I started on the ziricote. Especially with a fox bender. The trick is how quick, or slow you bend it. To fast and snap, to slow and the wood gets brittle and snap. It is not always easy to find just right. And moisture content and preservation of moisture (as in wrapped in foil) is also important.
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: guitarradTJ (Fri Jan 25, 2019 5:09 pm)
PostPosted: Fri Jan 25, 2019 5:11 pm
First name: Raul
Last Name: Ortiz
Thanks, it is my first. I'm have some inexpensive wood that I got a while back. Going to practice on that before I take a crack at the Ziricote [GRINNING FACE WITH SMILING EYES]
PostPosted: Sat Jan 26, 2019 5:37 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I do not have a lot of experience with Ziricote. Just one. I did a cutaway. Bent great. But I did a 24 hour soak with Super Soft II (craft paper and aluminum foil wrap)
These users thanked the author Mike OMelia for the post: guitarradTJ (Mon Jan 28, 2019 6:04 pm)
PostPosted: Fri Jul 31, 2020 5:00 pm
First name: Raul
Last Name: Ortiz
Well I finally started my first cutaway builds. This is Amazon Rosewood with Spruce. I used my Fox style side bender with no issues. I'm building 2 guitars, now I'm moving on to the Ziricote sides...Yikes!!
I have a gallon of Super Soft 2 on the way. I'm hoping this one will play just as nice as her sister.
Planning on soaking the sides overnight.
Any other tips, tricks or wise words are very much appreciated.
Thanks!!
PostPosted: Sat Aug 01, 2020 11:57 am
State: West Somerset
Country: UK
Nice to see a cutaway on a classical. I always do them on mine since as a (poor) player I find it helps a lot with those notes above the twelth fret.
These users thanked the author Dave m2 for the post: guitarradTJ (Mon Aug 03, 2020 11:24 pm)
Users browsing this forum: Bing [Bot] and 13 guests
