Sides for a cutaway
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=53243
Author:  SnowManSnow [ Fri May 22, 2020 10:38 am ]
Post subject:  Sides for a cutaway
Have I marked this out correctly?
I talked to a very knowledgeable member last night, and consulted Gore / Gilet so I believe I’m going about it right
This is for a 20s L1
Pic of mold is here to help with things
Sides
Body shape
Author:  Barry Daniels [ Fri May 22, 2020 11:21 am ]
Post subject:  Re: Sides for a cutaway
Just make sure you know and mark which is the inside and outside of each piece so you get it oriented in the bender correctly. The photo shows what I think is going to be the outside so that will be placed face down.
Author:  SnowManSnow [ Fri May 22, 2020 11:34 am ]
You’re correct
Author:  Trevor Gore [ Fri May 22, 2020 8:15 pm ]
Take care!
If you're using a Fox style bender as shown in the book (mine's a double width one), and those are the outsides of the sides in the pic, they will go face up in the bender for a right handed player. Check out Fig 8-2.
Another tip, but likely too late for this build as you have profiled the sides, is to put any swirly grain where the bending is least. So that "knot" close to the waist may have worked out better if the head end was at the other end of the side panels.
Author:  SnowManSnow [ Fri May 22, 2020 9:07 pm ]
Trevor Gore wrote:
Take care!
Trevor yes! I slapped my head when I really registered where that knot was. I hope it doesn’t cause too much issue.
I’m using a standard bending machine from blues creek.
I’ll triple check before I go to the bender what side is up and stuff.
I mean... it should just be like a standard bend with a preferred outside right
