Need a little help with white plastic bindings http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=53237 |
Author: | giltzow [ Tue May 19, 2020 1:34 pm ] |
Post subject: | Need a little help with white plastic bindings |
Hi All I do not usually use plastic bindings, but I am using white (Stewart McDonald ABS bindings) on an East Indian Rosewood B & S guitar. After scraping them flush and sanding I am getting a lot of EIR dust coloring in the white plastic. I am sanding to 220. Should I go finer on the grit? Or should I use Naptha, acetone or lacquer thinner to get the coloring out. How do you handle that? Thanks in advance for any help - Mike G |
Author: | Skarsaune [ Tue May 19, 2020 2:23 pm ] |
Post subject: | Re: Need a little help with white plastic bindings |
Scrape -just- the binding. Don't sand after scraping. |
Author: | Barry Daniels [ Tue May 19, 2020 3:25 pm ] |
I sand white plastic bindings up to 320 grit in order to keep sawdust from sticking. Then a blast of compressed air should get it clear. Scraping binding (especially the side of it) is challenging to get a mar free surface. |
Author: | Clay S. [ Tue May 19, 2020 3:37 pm ] |
Sanding to a finer grit as Barry suggested usually works. If you do decide to try scraping one thing I have found to work is to use a single edge razor blade and "round" the ends with a sharpening stone or sandpaper. That eliminates the sharp points that can create deep scratches in the plastic (or wood). I use plastic on most of the instruments I build. |
