Binding Help
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=53071
Author:  Matt Morgeson [ Sat Apr 04, 2020 12:58 pm ]
Post subject:  Binding Help
Help, with out going into detail I cut my binding channel too low.
I'm using .250 Koa binding. is there any place that will special cut
5/16 wide for me ?
Author:  Chris Ensor [ Sat Apr 04, 2020 1:15 pm ]
Post subject:  Re: Binding Help
Why not add purfling to the bottom of the binding you have now?
Author:  Matt Morgeson [ Sat Apr 04, 2020 1:35 pm ]
the back side is done, Koa with white trim.
cut the purfling channel ok then the binding
channel for the top but the Router base came loose
while cutting the channel. the binding now lines up with the bottom
of the purfling channel.
Author:  meddlingfool [ Sat Apr 04, 2020 7:10 pm ]
So you want bindings that are 5/16” in height?
Author:  DennisK [ Sat Apr 04, 2020 8:33 pm ]
If you have any koa back/side sets, slice some strips off the sides.
Author:  guitarjtb [ Sat Apr 04, 2020 8:42 pm ]
Inlay a dummy strip of binding, that matches your side wood, and re-cut the channels.
Author:  phavriluk [ Sun Apr 05, 2020 10:30 am ]
Note to OP: My opinion (I've bound only 5 guitars), and based on this comprehensive experience, I suggest finding a pleasing way to stack up 1/16" more of purfling and carry on. I think that this would be less problematic than trying to restore the channel. Make some lemonade. I've also seen binding purfling done with what usually gets put between the binding and the soundboard, is often 1/8" wide, or so, it was unusual and attractive to me,and sure looked 'custom'. Lots of variations and LMI doesn't charge shipping.
Author:  Tim L [ Sun Apr 05, 2020 12:23 pm ]
1st choice.. What Dennis K said
2nd choice...CurlyKoa.com
3rd choice...Volcano.com
I have 10pcs that are .109 x .350 x 35". If you have a drum sander send me am email.
Tim
Author:  Matt Morgeson [ Sun Apr 05, 2020 2:26 pm ]
yes
Author:  Joe Beaver [ Sun Apr 05, 2020 2:39 pm ]
What kind of wood did you use on the back/sides?
Author:  wbergman [ Sun Apr 05, 2020 5:37 pm ]
I have seen many very expensive guitars with different binding scheme on the top than on the back. Pretty much all have fancier purfling on the front. Do not feel self conscious if you add more rows on the top.
Author:  Matt Morgeson [ Mon Apr 06, 2020 8:10 pm ]
Guys, I can't thank you enough for responding. This is my 15th Dreadnought and I've never made this mistake before. it took the wind out of my sail
Joe, I used Cocobolo back and sides with white trim on the bottom of the Koa binding. I thought if I cut new binding at 5/16 with the white trim, scrape
level with the top the untrained eye would never know. Thanks to everyone for the help.
Author:  Joe Beaver [ Tue Apr 07, 2020 12:01 am ]
Matt,
That should work. The only other thing I could think of is, if you have the side cutoffs, then you could cut strips and glue them in. Then re-rout. most likely it would not show with rosewood. But... your method is much more straight forward and should look fine.
Double post for some reason.
Author:  Terence Kennedy [ Tue Apr 07, 2020 9:47 am ]
I would also say that with Cocobolo, binding it with the same wood or offcuts if you have them and then filling any gaps by sanding and thin CA could work great. If it does not look as good as hoped you can always rerout to original depth and go with plan B. No bridges burned.
Let us know what you wind up doing.
Author:  dofthesea [ Fri Apr 10, 2020 5:47 pm ]
Talk to Bob at Pegasus Guitars and Ukuleles. He can custom cut binding for you. he's great to work with and you can even ask for specific colors if there possible.
