It is currently Fri Sep 19, 2025 12:36 am
 Post subject: Welp....
PostPosted: Sun Oct 20, 2019 8:10 pm
First name: Brad
Last Name: Combs
This is a first. The bearing fell off while flush trimming the back after glue up. I caught it pretty quickly and the damage is not too bad. I think the binding will cover if I use the typical bwb purf that I like to use.
I guess just a PSA, check them bearings every once in a while? :D
These users thanked the author bcombs510 for the post: Pmaj7 (Mon Oct 21, 2019 12:22 am)
 Post subject: Re: Welp....
PostPosted: Sun Oct 20, 2019 8:17 pm
Last Name: Colbert
City: Anacortes
and also set the bit depth only as deep as necessary to get the job done. The bit is cheap ($20) compared to the cost of the wood and the time invested.
These users thanked the author Michaeldc for the post (total 3): dpetrzelka (Mon Oct 21, 2019 12:38 am) • Pmaj7 (Mon Oct 21, 2019 12:23 am) • bcombs510 (Sun Oct 20, 2019 8:27 pm)
PostPosted: Sun Oct 20, 2019 10:17 pm
Gulp! I’m equally impressed by your catch!
These users thanked the author James Orr for the post: bcombs510 (Mon Oct 21, 2019 7:28 am)
PostPosted: Mon Oct 21, 2019 7:21 am
Because of the number of posts I've seen where this has happened, I'm obsessive about checking it's tight before routing.
And it's great to get another reminder.
Nice catch!
These users thanked the author Colin North for the post: bcombs510 (Mon Oct 21, 2019 7:28 am)
PostPosted: Mon Oct 21, 2019 8:11 am
Every
Single
Time
These users thanked the author meddlingfool for the post (total 2): Pmaj7 (Wed Oct 23, 2019 4:04 pm) • bcombs510 (Mon Oct 21, 2019 8:55 am)
PostPosted: Mon Oct 21, 2019 9:06 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I have had things loosen on me while the router is on, and I never want that to happen again. I am now fairly obsessive about whether the bit is tight in the collet, whether the bearing is tight on the bit, and whether the height adjustment is locked (or plunging is dialed in right). I'm glad this one didn't turn into a real problem, Brad!
These users thanked the author doncaparker for the post (total 2): Colin North (Mon Oct 21, 2019 1:35 pm) • bcombs510 (Mon Oct 21, 2019 9:07 am)
PostPosted: Tue Oct 22, 2019 8:45 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
You might want to use loctite or another adhesive to lock down that router bearing. Its happened to me.
These users thanked the author Ernie Kleinman for the post (total 3): Colin North (Tue Oct 22, 2019 12:50 pm) • Michaeldc (Tue Oct 22, 2019 8:59 am) • bcombs510 (Tue Oct 22, 2019 8:56 am)
PostPosted: Tue Oct 22, 2019 9:34 am
Last Name: Ensor
City: Springfield
State: Missouri
This is why my Ultimate Binding Jig uses a guide that is mechanically attached. Seen this too many times.
(I use the tool for flushing plates)
http://elevatelutherie.com
http://ensorguitars.com
These users thanked the author Chris Ensor for the post: dpetrzelka (Tue Oct 22, 2019 1:27 pm)
Users browsing this forum: No registered users and 45 guests
