Fish Glue for Neck laminations?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=52308
Author:  Matthew Jenkins [ Wed Aug 28, 2019 12:07 pm ]
Post subject:  Fish Glue for Neck laminations?
Hi all.
Just a quick question;
I've just laminated a neck with Fish Glue but now I'm wondering if I should have stuck to Titebond?
Is Fish glue an appropriate glue for this job?
Many thanks
Matthew
Author:  jfmckenna [ Wed Aug 28, 2019 12:27 pm ]
Post subject:  Re: Fish Glue for Neck laminations?
IMHO yes it's perfectly well suited for such a job.
Author:  life_with_a_song [ Wed Aug 28, 2019 12:47 pm ]
Just started using it myself, and am really liking it thus far.
Author:  Tai Fu [ Sun Sep 01, 2019 5:02 am ]
I read fish glue does poorly in high humidity, remember not all countries are bone dry.
Author:  Clay S. [ Sun Sep 01, 2019 8:49 am ]
For a part you never want to come apart I would prefer a waterproof glue. If you are doing a dovetail joined neck that might eventually need to be steamed off the body, a water soluble glue might be problematic. For a bolt on it might be O.K..
Author:  bluescreek [ Sun Sep 01, 2019 10:54 am ]
in a dovetail the best glues are the water soluble glues . Sorry but I have been using fish glue for 15 years and no issues. I have guitars all over the world. One thing that is important with fish glue is clamp time. I clamp a minimum of 12 hr. 24 most of the time. I prefer hot hide glue on bridges as fish glue can sometime be harder to release. My glue of choice is always a good water based glue
tite bond original
fish and hot hide.
The more I do this the less I use CA , and thanks to Pat Deborro I now use west system epoxy for most cracks. the slow cure is perfect to glue penetration and is extremely strong
Author:  Clay S. [ Sun Sep 01, 2019 11:10 am ]
Hi John,
Do you use fish glue for laminating necks? It's always a good idea to use a water soluble for gluing the neck to body on a dovetail joint but for the laminations of the neck I would still prefer a waterproof glue.
Author:  Tai Fu [ Sun Sep 01, 2019 11:19 am ]
Agreed. I use Titebond II for all neck lamination or construction except for fingerboard (they may need removal in the future). Titebond is heat and moisture resistant.
I am stopping any glued in dovetail necks though... too much issues with necks coming off. I never had any failure with bolt on necks but it seems dovetail necks want to come off if condition is not EXACTLY right (little too much heat, moisture, or both). I'm sure I'm not doing something exactly right but dovetail just demands a very exact fit, but bolt on allows a little wiggle room...
Author:  Chris Ensor [ Sun Sep 01, 2019 4:44 pm ]
Just don’t use a water based finish over it...
Author:  Colin North [ Sun Sep 01, 2019 4:50 pm ]
I've done water based finish over bindings glued with fish glue.
Initially it shows, but after 3/4 coats and sanding level, no problems.
I saw in a post on another forum where Todd Stock found the same thing.
Author:  bluescreek [ Sun Sep 01, 2019 6:14 pm ]
I use tite bond original for gluing up 2 pc necks
I am sure any strong glue will work for this.
Author:  bluescreek [ Sun Sep 01, 2019 6:16 pm ]
tai fu after 20 yrs and 1000 dovetails if you had failures , something in your technique may be the problem. Can you tell us your process and if you have pictures. I proper dovetail is stronger than any bolt on neck.
Author:  Ernie Kleinman [ Mon Sep 02, 2019 8:03 am ]
Lke John I use a lot of fish glue . Just pulled some from the freezer. For bridges 310 g HHG . and titebond for some neck laminations, carpentry and cabinetwork . Our local dollar store sells a plain white glue 8 oz for $1, it is also useful , as it has a lot of open time . I would think that fish would work well for laminating neck heels . One of its strengths is long open time and fast tack, which I prefer.
