It is currently Thu Sep 18, 2025 1:40 am
PostPosted: Wed Apr 10, 2019 12:28 pm
How in the world does one achieve that stained glass looking rosette look? I’ve seen some really interesting ones from Jason Kostal. Does one piece together a flat of the design and then just cut the rosette from that ?
Was just curious as to if anyone here had attempted it.
PostPosted: Wed Apr 10, 2019 4:13 pm
I'm not a fan the look, but I do segmented rosettes by supergluing segments to a 0.4 or 0.8mm ply backing and then cut out the rosette itself, inlay into the top, then rout purfling grooves and fit.
Also works for delicate rosettes like spalted wood or burrs etc.
These users thanked the author Colin North for the post: SnowManSnow (Wed Apr 10, 2019 7:17 pm)
PostPosted: Thu Apr 11, 2019 6:17 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I did this for the WILS in 2013. It was done just by routing out the rosette trench and carefully cutting each piece to fit and tacking it in with a dab of HHG. Then it was filled with black epoxy and leveled. I had saved a lot of shell scrap thinking I could use it for somethjing like this but to get a nice even look I wound up laying out and cutting each piece...
Brian
These users thanked the author B. Howard for the post (total 2): TimAllen (Fri Apr 12, 2019 12:49 am) • SnowManSnow (Thu Apr 11, 2019 7:29 am)
PostPosted: Thu Apr 11, 2019 7:29 am
Very unique and super labor intensive! Thanks for sharing
PostPosted: Thu Apr 11, 2019 6:43 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I have done a couple of these. Yes, as you predicted, you cut lots of individuat pieces and glue them together with bits of black or bwb purfling strip between them. Do it on a flat board like making a jig-saw puzzle. You just make up a square (or a donut, since the middle is discarded) and then cut the ring out and inlay it as a single piece. Jason Kostal makes his beautiful multi-coloured ones from maple or other light timbers which are pre-dyed. The trick there is to get the dye to penetrate so that it doesn't just sand off. I have not done coloured woods for mine, I just save offcuts of woods with different naturally occuring colours and make a mosaic with them. It is fiddly and takes quite a while - but I love the result.
These users thanked the author Mark Mc for the post: SnowManSnow (Thu Apr 11, 2019 7:24 pm)
PostPosted: Thu Apr 11, 2019 8:30 pm
First name: Kent
Last Name: Fishburn
City: Woodstock
State: Illinois
Check out Voss guitar. He does a tutorial on his site
http://startingvossguitars.blogspot.com/2014/12/rosette-no2.html
PostPosted: Thu Apr 11, 2019 9:45 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
The site above gives a very good tutorial on how to make the rosette. If you're looking to use dyed burl like Jason he had mentioned to me that he puts the dye and burl in a pressure cooker at a low setting for a a day or two so that the dye fully penetrates the wood
Users browsing this forum: Bing [Bot] and 25 guests
