Sound port reinforcement http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=51677 |
Author: | SnowManSnow [ Sun Mar 03, 2019 3:50 pm ] |
Post subject: | Sound port reinforcement |
So I’ve done ports with a reinforcement where I’ve basically laminated that area, but what would be the downside in reinforcing it with epoxy and a fiberglass mesh? Sent from my iPhone using Tapatalk |
Author: | meddlingfool [ Sun Mar 03, 2019 3:52 pm ] |
Post subject: | Re: Sound port reinforcement |
Uglieness? |
Author: | Mark Mc [ Sun Mar 03, 2019 4:16 pm ] |
Probably lots of ways to skin that cat. I have seen guitars that just had a hole drilled in the side without any reinforcement and it worked fine. CF plastered on the inside with epoxy would help prevent cracks from originating at the hole. But I agree with Ed that it might not be the best look. I laminate a piece of side cut-off, bent to fit, to make a cross-grain patch inside. It can look good if you sandwich a contrasting veneer in the middle which gets revealed as a ring at the opening, and can tie into your purfling scheme. Binding the hole looks classy too, and affords extra protection to the rim. |
Author: | muse [ Mon Mar 04, 2019 12:16 am ] |
Mark Mc wrote: Probably lots of ways to skin that cat. I have seen guitars that just had a hole drilled in the side without any reinforcement and it worked fine. CF plastered on the inside with epoxy would help prevent cracks from originating at the hole. But I agree with Ed that it might not be the best look. I laminate a piece of side cut-off, bent to fit, to make a cross-grain patch inside. It can look good if you sandwich a contrasting veneer in the middle which gets revealed as a ring at the opening, and can tie into your purfling scheme. Binding the hole looks classy too, and affords extra protection to the rim. What Mark Mc said... ![]() |
Author: | Pat Foster [ Mon Mar 04, 2019 10:37 am ] |
I'd prefer cut out a soundport backed with just about any wood rather than fiberglass. |
Author: | Linus [ Mon Mar 04, 2019 8:49 pm ] |
If you are binding the hole no one will notice. If they go looking inside with a mirror they will see it so if you choose that route, just do a clean job of it. I laminate cross grained wood and bind the hole. It looks good and works well. |
