Patagonia Rosewood for Fingerboard & Bridge? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=51541 |
Author: | sdsollod [ Fri Feb 01, 2019 10:11 am ] |
Post subject: | Patagonia Rosewood for Fingerboard & Bridge? |
Is Patagonia Rosewood suitable for fingerboard and bridge (and bridge plate)? |
Author: | Casey Cochran [ Fri Feb 01, 2019 11:31 am ] |
Post subject: | Re: Patagonia Rosewood for Fingerboard & Bridge? |
I smell an upcharge... Plaster a Fitz Roy decal on there and start making some big deposits! ![]() |
Author: | Clay S. [ Fri Feb 01, 2019 12:36 pm ] |
Patagonian rosewood (A.K.A. curupay, cebil) is a trade name used by the flooring industry for a semi-tropical south american hardwood. It's harder than ebony and shrinks less, so as long as you find a nice stabile piece and don't mind working with a wood that dulls cutters ( don't many alternative fingerboard woods) it should - probably (weasel word alert) - be fine. If you are picking through flooring boards try to find a nice quartersawn piece. |
Author: | sdsollod [ Fri Feb 01, 2019 2:21 pm ] |
Woodcraft sells this stuff and has it on sale. Not sure I'm interested, but I thought I'd check to see what folks thought of it... |
Author: | Clay S. [ Fri Feb 01, 2019 9:44 pm ] |
Ipe (brazilian walnut), jatoba (brazilian cherry), curupay (patagonian rosewood) - the flooring industry dresses them up with fancy names which others adopt. If you look at the woods for what they are and are not put off by the sales tactics they have some pretty nice qualities. As long as there were woods that were easier to mill they were not commonly used but with the scarcity of the usual hardwoods and the common usage of carbide tooling they are coming to market. When I run low on fretboard stock I will certainly give them a second look. |
Author: | Toonces [ Sat Feb 02, 2019 12:46 am ] |
I've been using it for years as my bridge plate material. I don't think I would ever use any other wood as it is perfect for what I'm after. It's got a nice tap tone as well. |
Author: | meddlingfool [ Sat Feb 02, 2019 1:35 am ] |
Hmm. I’d love a better bp material than maple. Can you just find this stuff at Ye Olde Floore Shoppe? |
Author: | Clay S. [ Sat Feb 02, 2019 9:33 am ] |
Hi Ed, This might get you a small stock of brigeplates to try: www.brazilianhardwood.com/products/samples/ |
Author: | meddlingfool [ Sat Feb 02, 2019 11:33 am ] |
Thanks! |
Author: | Ruby50 [ Sat Feb 02, 2019 1:49 pm ] |
OsageE orange for bridgeplates? Plenty available cheap. Ed |
Author: | Clay S. [ Wed Feb 06, 2019 1:00 pm ] |
Here are the samples from the company linked above. The longer ones are 7 inches long. Losing the T&G and the bottom grooves leaves a piece about 2 5/8 wide and 5/8ths thick - enough for a few bridge plates or a couple of bridges. The wood is attractive and looks like it could make nice back and side sets. |
