Sycamore back bracing http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=51230 |
Author: | surveyor [ Thu Nov 15, 2018 12:25 pm ] |
Post subject: | Sycamore back bracing |
No. 13 is going to be Sycamore back and sides from a neighbor's tree. Just wondering which wood some of you might prefer for bracing on the back. It will have a spruce top and I use spruce for top braces. I have plenty of maple and walnut, maybe one of those? ![]() |
Author: | surveyor [ Thu Nov 15, 2018 12:43 pm ] |
Post subject: | Re: Sycamore back bracing |
Or just more sycamore for the braces? |
Author: | DannyV [ Thu Nov 15, 2018 1:01 pm ] |
I like Spruce! Others can work. Spruce has the stiffest strength to weight ratio..... typically. |
Author: | Clay S. [ Thu Nov 15, 2018 3:18 pm ] |
If you want a stiff and heavier reflective back (which is not a bad way to go on that size guitar) maple might not be a bad choice. I think it would look better than walnut. If your sycamore is spalted I would avoid it for braces. |
Author: | surveyor [ Thu Nov 15, 2018 5:23 pm ] |
I'll avoid using any "spalted" wood for braces since the spalting is usually caused by fungi or decay, even though it looks cool. I just broke one of the spalted sycamore sides I had prepared, after bending it. I was flexing it before putting it into the mold and the upper bout broke clean across. That wasn't cool...but I didn't get mad, since I have more and I found out at an early stage that it was faulty. |
Author: | olmorton71 [ Fri Nov 16, 2018 3:21 am ] |
That’s going to be a nice back. I’d use spruce braces Sent from my iPhone using Tapatalk |
Author: | Ernie Kleinman [ Fri Nov 16, 2018 8:03 am ] |
Check out the density of your spruce . They are not created equal. Sitka has the stiffest weight to density ratio IMHO |
