Cutting Brace Ends http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=51198 |
Author: | Colin North [ Tue Nov 06, 2018 7:31 pm ] |
Post subject: | Re: Cutting Brace Ends |
Neat. I've just started using a Hosco brace saw (convex) for my brace ends. Just cut until I feel the glue, chisel off the nub and then use hot water to remove the glue and any traces of wood remaining |
Author: | Rod True [ Tue Nov 06, 2018 11:37 pm ] |
Nice Mac Ebony (assume...) there Terrance! Great tip. |
Author: | Terence Kennedy [ Wed Nov 07, 2018 12:50 am ] |
Thanks Rod. Actually it is some great Brazilian from fellow forum member Hans Brentrup ![]() |
Author: | Rod True [ Wed Nov 07, 2018 12:55 am ] |
Wow! Super dark... can't wait to see more of that one... |
Author: | doncaparker [ Wed Nov 07, 2018 6:38 am ] |
Does anyone use a veneer saw for this task? I have one, but I have not tried it for this yet (I have only used it for its intended purpose). Veneer saws have thin, convex blades, so I was thinking it would be a good tool for avoiding the collateral damage a flat saw blade can cause. |
Author: | Ruby50 [ Wed Nov 07, 2018 7:54 am ] |
I have used a veneer saw and it works well. I put a little piece of blue tape on either side of the brace and when the blade hits the tape, the convexity? of the blade means it is through enough. Cheap and available. You can even buy just the blade and screw it through the holes onto a stick: https://www.amazon.com/Kunz-Veneer-Saw-Replacement-Blade/dp/B0034YUVM6/ref=sr_1_7?ie=UTF8&qid=1541595173&sr=8-7&keywords=veneer+saw Ed |
Author: | doncaparker [ Wed Nov 07, 2018 10:34 am ] |
Thanks, Ed. I own two of them; I look forward to devoting one to this task. I always seem to nick the soundboard when using a regular, flat blade razor saw. |
Author: | Clay S. [ Wed Nov 07, 2018 11:16 am ] |
I used to use a veneer saw, but now use an oscillating tool with a half moon blade. I've found a multitude of uses for that tool. |
Author: | whiskywill [ Wed Nov 07, 2018 11:19 am ] |
I use one of these which I found recently on eBay. https://www.flinn-garlick-saws.co.uk/ac ... y_Saw.html It was new and less than half the listed price. I was the only one who bid for it. ![]() |
Author: | David Wren [ Sun Nov 11, 2018 5:05 pm ] |
Nice tip Terence ... thanks for posting |
