It is currently Fri Sep 19, 2025 5:50 pm
 Post subject: Arm bevel question
PostPosted: Sat Sep 15, 2018 3:13 pm
City: Tyler
OLF’s - can someone help me understand something I have not been able to wrap my mind around?
I love arm bevels, but don’t get how the veneer can be glued down on what is a conical surface. It seems to me that the veneer will tend to kink with the inside radius being smaller than the outside. Does the water in the glue just make it pliable enough that it’s not an issue? Is it that simple?
 Post subject: Re: Arm bevel question
PostPosted: Sat Sep 15, 2018 3:30 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
While what you're thinking may be true the veneer lays pretty flat. A piece of paper to make a close template, cut veneer same. glue and
tape it on. That part is that simple imo.
These users thanked the author Ken Lewis for the post: Glen H (Sun Sep 16, 2018 11:48 am)
PostPosted: Sat Sep 15, 2018 4:52 pm
Last Name: Sollod
I learned how to do it from Kent Everette's video class on Robbie O'Brien's website. Kent encourages folks to flatten the area where the veneer goes. He says it looks better. I would expect that it would also allow the veneer to fit better too...
www.swiftcreekguitars.com
PostPosted: Sat Sep 15, 2018 5:12 pm
I’ve done them both ways. What I’ve found is that unless I use elaborate cauls when taping/gluing the veneers, it’s helpful to have a slight convexity to the bevel surface. Otherwise, due to the slight overhang of the oversized veneers, the tape can pull down the edges such that it creates a gap in the center of the veneer. Also, I feel the bevel is more comfortable and looks better being a bit rounded over. Image
Mountain Song Guitars www.mountainsongguitars.com
These users thanked the author Ken Jones for the post: Michaeldc (Sat Sep 15, 2018 7:19 pm)
