Final sandings of neck - shoulder/heel
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=50916
Author:  Colin North [ Wed Aug 22, 2018 2:41 am ]
Post subject:  Final sandings of neck - shoulder/heel
When final sanding the neck, how do you deal with the shoulder of the heel where it meets the body?
It's very easy to round over this area instead of keeping it "sharp".
And even more difficult to sand epoxy or level sand finish in this area without sand-through.
Author:  Glen H [ Wed Aug 22, 2018 7:17 am ]
Post subject:  Re: Final sandings of neck - shoulder/heel
When I sand there I wrap paper around a hard backer, usually a half inch aluminum rod. Sometimes other backers. And one of the reasons I don’t use export filler on the neck. I use oil based pore filler on the neck . Epoxy on the body.
Author:  Woodie G [ Wed Aug 22, 2018 7:23 am ]
A block or firm foam (rigid foam) block works both to avoid rounding over the contour and for sanding the epoxy filler. A longer block is easier to see the angle being worked...just maintain a few degrees beyond square to avoid issues.
Re: epoxy filler, it is particularly important to remove excess epoxy on complex contours because it is much more difficult to scrape the excess...it turns what can be a quick job on the flat to tedious on the round.
