It is currently Fri Sep 19, 2025 12:20 am
PostPosted: Fri Jun 01, 2018 6:57 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I am binding a fretboard and have a question
On an ebony board, I am contemplating a .06 abalone strip down either edge, with about a .06 ebony strip outside of that. That leaves about .12 outboard of the actual ebony board down either edge. I am thinking that the frets will not like seating in the abalone, so the cut off tang will have to span the entire .12 of the combined ebony/abalone edging.
Is this too much for no tang??
Something like this, but with different materials and the fret slot not continuing through the "white" part
Ed
PostPosted: Fri Jun 01, 2018 8:20 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
My experience here is that for 18% nickel silver wire, up to 0.188" of crown free of the tang is tolerable with good technique (i.e., careful pre-bending of crown). If there is an option to use either EVO or stainless, you can get some additional resistance to distortion should an edge get caught, etc. All this supposes the frets are glued in to minimize the opportunity for grime and perspiration to accumulate under the fret crown.
- Beth Brower
These users thanked the author Woodie G for the post (total 2): Pmaj7 (Fri Jun 01, 2018 9:16 am) • Jules (Fri Jun 01, 2018 8:44 am)
PostPosted: Fri Jun 01, 2018 10:36 am
fwiw, for me, it's crown width max. anything more seems to require "aids" in order to minimize risk. if you need more, remove whatever barbs are going through the shell and run the slot right into the ebony.
PostPosted: Fri Jun 01, 2018 1:36 pm
I did one recently and I am pretty sure I cut through the abalone.
.Image
PostPosted: Fri Jun 01, 2018 1:58 pm
Last Name: Beaver
City: Lake Forest
I wouldn't expect any problem with cutting thru the shell and putting a tang into it.
I would do it the same way you did in the photo, route a ledge on the board, install shell, cut the fret slots through the shell and then bind. That will leave you with .06" of no tang, perfect!!!
Joe Beaver
Maker of Sawdust
PostPosted: Fri Jun 01, 2018 4:20 pm
I do these on a regular basis
I will use poly when I bind the board then set about a.030 gap at the fret slot.
Users browsing this forum: Bing [Bot] and 28 guests
