It is currently Thu Sep 18, 2025 6:06 am
PostPosted: Tue May 08, 2018 6:04 pm
GLUBOOST
Total Placement Control of Adhesives And Finishes – New GluBoost EndPoint Mark + Mask System
When you need precise application without run off, our EndPoint Mark + Mask System creates a spot on perimeter with complete runoff control.
GluBoost EndPoint Mark + Mask System eliminates adhesive and finish run off forever! The ideal accessory for the complete control of where the glue or finish runs or doesn’t. The included Perimeter Markers + Ultra High Performance tape are both specially formulated keep the glue contained in a chosen area on any surface.
These kits are specifically designed to work/for use with MasterGlu adhesives and Fill n’ Finish formulas and are simple to use.
Click here to watch how the EndPoint Mark + Mask System gives you complete application control.
https://www.youtube.com/watch?v=rM2n1-zHRDg and https://www.youtube.com/watch?v=af2yKTkEbk8
Click here http://www.GluBoost.com for more information on our EndPoint Mark + Mask System and other fine GluBoost products.
Featured Products (Both FnFs and MGs)
Now you can control spot placement of the market's very best adhesives and finishes!
Contents: One roll of 36 yard by 1/8” wide, bright green, high tack vinyl tape and one box of 3 non-toxic yellow glue and finish Perimeter Markers. PHOTO?
High Precision Top Quality Vinyl Tape with the Highest Tack Tape Available
Full 36 yards by 1/8” wide for finer control
Allows for repeated removal and replacement for more exacting work
Sturdy plastic core
Write-on capability
Resistant to aging, sun, water, fungus, bacteria, oil, acids, alkalis, and corrosive chemicals
Abrasion, impact and rupture resistance.
Easy to ID Bright Green Color
Perimeter Markers
Bright yellow color
Resists adhesive and finishes
Marks a perimeter where glue or finish will not go
Soft, easy to use material
Non-toxic
PostPosted: Tue May 08, 2018 9:17 pm
First name: Craig
Last Name: Gordon
Zip/Postal Code: 14216
I just bought some. Can't wait to try it out
