It is currently Wed Aug 06, 2025 9:03 am
PostPosted: Tue May 01, 2018 7:45 pm
Been a long time since I've had a problem, but today I bent up some Aussie Blackwood and it turned a lovely shade of green. I know it will sand out eventually, but I recall there may be a solution that removes the stain. Oaxic acid or something maybe?
PostPosted: Tue May 01, 2018 9:31 pm
First name: Trevor
Last Name: Gore
City: Sydney
Oxalic acid will do the job. Over do it, blackwood will go a bronzey colour. Not unattractive, but maybe not what you want. Wash the oxalic off with dilute white vinegar, then water. Anything with a basic pH (i.e. alkaline) will turn it green or black again.
http://www.goreguitars.com.au
PostPosted: Wed May 02, 2018 12:05 am
Are you saying it will go a bronze color if I overdo the acid?
PostPosted: Wed May 02, 2018 3:38 am
First name: Trevor
Last Name: Gore
City: Sydney
Yes. There is more red to the colour, heading in a mahogany direction. It's not unattractive, but may not be what you had in mind. Check it out on an off-cut. Some blackwood starts out that colour anyway, but if it went green on you it probably started out more on the brown side.
PostPosted: Wed May 02, 2018 7:14 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I oversize my sides to possibly remove stains , anomalie,s etc with a very small sharp scraper blade as found in a stanley number 80 scraper
PostPosted: Wed May 02, 2018 9:37 am
Thanks folks!
Fortunately most of it is on the inside. I reflect on the irony of how I can go dozens and dozens of guitars problem free on the budget line, but as soon as it's a show glossy with a deadline, things go squirrelly...Image
This is its color, and the color I'd like for it to stay.
PostPosted: Wed May 02, 2018 11:33 am
I think this is the stuff I'm after?
https://www.homedepot.ca/en/home/p.all- ... 39775.html
PostPosted: Wed May 02, 2018 11:51 am
Turns out you can get it in crystal form at Shoppers Drug Mart! That store gets better and better:)
PostPosted: Wed May 02, 2018 12:18 pm
Many paint stores carry oxalic acid. It is poisonous so use a little bit of care ( don't put it near your coffee mug).
PostPosted: Wed May 02, 2018 5:09 pm
First name: Trevor
Last Name: Gore
City: Sydney
I get it in crystal form from the hardware store, just labeled Oxalic Acid. Use "rubber" gloves.
PostPosted: Wed May 02, 2018 5:19 pm
Thanks Trevor! What is the mix ratio, and are nitrile gloves "rubber" enough?
PostPosted: Wed May 02, 2018 10:22 pm
First name: Trevor
Last Name: Gore
City: Sydney
meddlingfool wrote:
...are nitrile gloves "rubber" enough?
Anything that will keep it off your hands. Nitrile should be fine.
meddlingfool wrote:
What is the mix ratio...
The directions on my stuff say 250gm per litre. However, I use it at much lower dilutions, probably more like a tablespoon per pint, or a teaspoon per jam jar. Test, test, test. You may have to treat the back too, to get a good colour match.
These users thanked the author Trevor Gore for the post: Dmaxwell (Wed May 02, 2018 11:47 pm)
PostPosted: Wed May 02, 2018 11:44 pm
Thanks very much!
