In Search Of .............. ( FOUND RC TONEWOODS ) http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=50433 |
Author: | WudWerkr [ Mon Mar 19, 2018 2:25 pm ] |
Post subject: | In Search Of .............. ( FOUND RC TONEWOODS ) |
Curly Narra .... Enough for a head plate 4"x 7" x .070 . AKA Amboyna ![]() ![]() |
Author: | bcombs510 [ Mon Mar 19, 2018 2:33 pm ] |
Post subject: | Re: In Search Of .............. |
WudWerkr wrote: Curly Narra .... Enough for a head plate 4"x 7" x .070 . AKA Amboyna ![]() ![]() Is RC out of stock? http://rctonewoods.com/RCT_Store/headpl ... =3&sort=1a Brad Sent from my iPhone using Tapatalk |
Author: | WudWerkr [ Mon Mar 19, 2018 3:07 pm ] |
bcombs510 wrote: WudWerkr wrote: Curly Narra .... Enough for a head plate 4"x 7" x .070 . AKA Amboyna ![]() ![]() Is RC out of stock? http://rctonewoods.com/RCT_Store/headpl ... =3&sort=1a Brad Sent from my iPhone using Tapatalk There's looks darker , Maybe just me ? Attachment: 100_3194.JPG
Author: | WudWerkr [ Mon Mar 19, 2018 3:16 pm ] |
Emailed RC to see if they can match it . |
Author: | bcombs510 [ Mon Mar 19, 2018 6:00 pm ] |
WudWerkr wrote: Emailed RC to see if they can match it . Wow, it really does look different. Hopefully they can match it up for you! Sent from my iPhone using Tapatalk |
Author: | geetarman77 [ Tue Mar 20, 2018 7:46 am ] |
Did they wipe there’s with naphtha to show grain? Sent from my iPhone using Tapatalk |
Author: | Bobc [ Tue Mar 20, 2018 11:26 am ] |
Never seen any curly narra that looked like your picture. It is usually much darker and redder. |
Author: | Bryan Bear [ Tue Mar 20, 2018 11:42 am ] |
Bobc wrote: Never seen any curly narra that looked like your picture. It is usually much darker and redder. Interesting. I have one set that I was told was narra that is just about the same color as Wud's. Wud, where did you get it? I got mine from Tom Rein before he moved to Michigan. I know you have met him so maybe this is not a coincidence. This is the only narra I have ever had or handled but it looked about the same color as the narra sample on The Wood Database: http://www.wood-database.com/narra/ so I never really questioned it. EDIT: In no way was I trying to imply that Tom was misleading anyone about tonewoods (if it came off that way). I was merely wondering it our sets came from the same stock. . . |
Author: | WudWerkr [ Tue Mar 20, 2018 3:31 pm ] |
Bryan Bear wrote: Bobc wrote: Never seen any curly narra that looked like your picture. It is usually much darker and redder. Interesting. I have one set that I was told was narra that is just about the same color as Wud's. Wud, where did you get it? I got mine from Tom Rein before he moved to Michigan. I know you have met him so maybe this is not a coincidence. This is the only narra I have ever had or handled but it looked about the same color as the narra sample on The Wood Database: http://www.wood-database.com/narra/ so I never really questioned it. EDIT: In no way was I trying to imply that Tom was misleading anyone about tonewoods (if it came off that way). I was merely wondering it our sets came from the same stock. . . Be honest with you I dont think so . However I had this in my shop for a yr or so before I started it . Seems i bought it here from someone in classified . However I have slept since then . And I know T. Rein , Hes a straight up guy. |
Author: | WudWerkr [ Tue Mar 20, 2018 3:43 pm ] |
Heartwood can vary widely in color, ranging from a golden yellow to a reddish brown. Pale yellow sapwood is clearly demarcated from the heartwood. Quartersawn surfaces display ribbon-stripe figure, and the wood is also seen with mottled, beeswing, or curly figure. Narra burl is full of well-defined knot clusters, and the highly valued wood is known as Amboyna. I believe this is crux of the matter |
Author: | WudWerkr [ Mon Mar 26, 2018 12:25 pm ] |
Bobc wrote: Never seen any curly narra that looked like your picture. It is usually much darker and redder. Got the head plates today . The narra will work just fine . Alot closer in person than pics showed . Thank you for the extra piece .I sincerely appreciate your help on this ![]() ![]() ![]() ![]() |
Author: | bcombs510 [ Mon Mar 26, 2018 12:35 pm ] |
Post subject: | Re: In Search Of .............. ( FOUND RC TONEWOODS ) |
Glad it worked! |
