PSA http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=50425 |
Author: | bcombs510 [ Fri Mar 16, 2018 7:02 pm ] |
Post subject: | PSA |
Just wanted to let you guys know that DNA and Naptha do two different things. One will highlight the ridges in your epoxy pore fill so you can level them. The other will level the ridges for you while simultaneously making a mess of the fill. Manufacturer suggests if you store them in your own bottles that those bottles be very clearly marked. The more you know. Knowing is half the battle. Sent from my iPhone using Tapatalk |
Author: | Clay S. [ Fri Mar 16, 2018 8:38 pm ] |
Post subject: | Re: PSA |
There is always the sniff test. Knowing is half the bottle. Hic! |
Author: | dpetrzelka [ Fri Mar 16, 2018 8:49 pm ] |
Denatured Alcohol is so much more powerful a solvent than you would think. |
Author: | mountain whimsy [ Fri Mar 16, 2018 9:41 pm ] |
Clay S. wrote: Knowing is half the bottle. Hic! You beat me to it..... |
Author: | Jim Watts [ Fri Mar 16, 2018 10:16 pm ] |
DNA shouldn't do much to epoxy if it's ratio is right, it's mixed well and it's cured. |
Author: | bcombs510 [ Fri Mar 16, 2018 11:01 pm ] |
Yeah, in the end it wasn’t as big a deal as I had thought. I put it down and walked away. The good news is that I was able to finish up my 30’ radius workboard, so there is that. ![]() Sent from my iPhone using Tapatalk |
Author: | Pat Foster [ Sat Mar 17, 2018 11:02 am ] |
dpetrzelka wrote: Denatured Alcohol is so much more powerful a solvent than you would think. Works real good on livers. |
Author: | rlrhett [ Sat Mar 17, 2018 12:22 pm ] |
I wouldn’t have thought to use either. What do you wipe naphtha on for? Sent from my iPhone using Tapatalk Pro |
Author: | J De Rocher [ Sat Mar 17, 2018 1:08 pm ] |
Ok, based on the posts above, I'm confused which one is which. I always put an epoxy/ethanol 50:50 wash coat on as my last epoxy coat and the ethanol in that doesn't cause any problem for the epoxy already on. I haven't tried naptha on epoxy. I don't know about Brad, but I use naptha to clean fine sanding dust out of wood and it's really good for highlighting surface flaws like small scratches. It doesn't evaporate as quickly as ethanol so you have a longer viewing time. |
Author: | Clay S. [ Sat Mar 17, 2018 1:56 pm ] |
DNA can soften uncured epoxy more or less depending on the denaturant . MEK is sometimes used and will soften epoxy. Epoxy takes a few days to fully cure so that could be a factor also. I think in some cases the epoxy will re-harden without ill effect. |
Author: | bcombs510 [ Sat Mar 17, 2018 3:09 pm ] |
J De Rocher wrote: I don't know about Brad, but I use naptha to clean fine sanding dust out of wood and it's really good for highlighting surface flaws like small scratches. It doesn't evaporate as quickly as ethanol so you have a longer viewing time. Sorry, this post was intended to be more of a joke highlighting what an idiot I can be at times. ![]() I use the naphtha same as Jay. When I’m leveling epoxy it can sometimes be hard to see the remaining imperfections. Wiping naphtha on highlights them for me so I can take care of it. Brad Sent from my iPhone using Tapatalk |
