It is currently Sat Jul 19, 2025 6:38 pm
 Post subject: Rocklite Ebano bindings
PostPosted: Fri Feb 09, 2018 11:22 pm
First name: David
City: Napa
Zip/Postal Code: 94558
Has anyone tried out the Rocklite Ebano bindings or fretboard whats the world on the street? does it bend easy do you bend it at the same temp as wood? does it look correct or kind of off?
PostPosted: Sat Feb 10, 2018 12:20 am
Last Name: Shanklin
City: Windsor
State: ON
Check with Uncle Bob at R C Tonewoods from the sponsor page. He should be able to tell you every thing about them as he sells them.
Bob
PostPosted: Sat Feb 10, 2018 3:50 am
First name: Gary
Last Name: Leddington
I just used some on a guitar that will be traveling over borders alot... hence the non-use of ebony in the case that it goes on the CITES list.
They work, bend and sand like a charm. I bent them with a blanket on my Fox Bender...
They look black as can be... no defects or different shades here and there. Uniform and dark.
I recommend them.
G.
www.leddingtonguitars.com
These users thanked the author Fasterthanlight for the post (total 2): James Orr (Sat Feb 10, 2018 4:48 pm) • Pmaj7 (Sat Feb 10, 2018 6:00 am)
PostPosted: Sat Feb 10, 2018 9:23 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I used Rocklite for the fretboard and bridge on an experimental guitar last year. The stuff looks and works great, but is softer and less dense than Ebony. Advertised as about the hardness of Rosewood, you can dent it with a thumbnail. And it makes a much lighter bridge than an identical Ebony bridge.
It will probably be alright.
These users thanked the author Greg Maxwell for the post (total 2): Pmaj7 (Sun Feb 11, 2018 8:45 am) • James Orr (Sat Feb 10, 2018 4:48 pm)
PostPosted: Sat Feb 10, 2018 12:30 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Here's a Cnd. source, Bob. https://www.woodtoworks.com/Rocklite-Eb ... 13086.html
Alex
PostPosted: Sat Feb 10, 2018 7:59 pm
First name: David
City: Napa
Greg does it have similar musical qualities as ebony? I'd be nervous using it as a bridge considering its makeup.....
PostPosted: Sun Feb 11, 2018 7:36 am
Martin has been using it for years.
PostPosted: Sun Feb 11, 2018 10:57 am
First name: David
City: Napa
John do know if they use it on the vintage reissues or the higher level instruments?
PostPosted: Sun Feb 11, 2018 8:10 pm
no only on lower end guitars it replaced mycarta . it is also used with the kits
PostPosted: Sun Feb 11, 2018 8:31 pm
First name: Danny
Last Name: Vincent
I have purchased it for all acoustic applications and so far only uses the head plates on 2 guitars. I like it! No pores and works well for cutting inlay. The bindings should bend well and are quite dense. I've heard rumour of the FB slots crumbling during refrets but that's not first or even second hand so IDK. I'm not sure if I will ever bring myself to use the bridge blank but I may turn the blank into a bridge one day and go from there.
There is a guy named Dan McPherson out of Penticton BC who sells it also. He builds very nice electrics and uses it a lot.
PostPosted: Tue Feb 13, 2018 3:40 pm
First name: nigel
Last Name: forster
City: Newcastle upon tyne
Zip/Postal Code: ne12at
Country: england
I prefer it to ebony. It bends easier, and for bridges it's superb.
nigel
http://www.theluthierblog.com
PostPosted: Wed Feb 14, 2018 1:27 pm
First name: Danny
Last Name: Vincent
Good to hear Nigel. I've got a bridge blank. I'll shape it up on my next run of bridges!
PostPosted: Wed Feb 14, 2018 2:36 pm
I've refretted one (Martin) and had no problems, admittedly the first refret. Martin says you can do several times, much the same as a normal fretboard.
