Latest classical rosette http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=50032 |
Author: | Paul Micheletti [ Fri Dec 08, 2017 4:30 pm ] |
Post subject: | Latest classical rosette |
Hi Folks, I wanted to share a picture of my latest rosette. I like to make my own end-grain mosaic tile rosettes. This alternating rams horn motif is one I've used on my last few guitars. But this one has an additional twist. Can you guess my customer's name given only what you see in this photo? ![]() ![]() If you are interested in how I create these rosettes, I've written up the process here. Enjoy! http://www.pemicheletti.com/rosette-mosaic-part-1-of/ http://www.pemicheletti.com/rosette-mosaic-part-2-of/ http://www.pemicheletti.com/rosette-making-part-3-of-3/ Paul M. |
Author: | bcombs510 [ Fri Dec 08, 2017 4:37 pm ] |
Post subject: | Re: Latest classical rosette |
Tell Mr Jacobs I said hello! Brilliant! |
Author: | Clay S. [ Fri Dec 08, 2017 7:50 pm ] |
So are the inner and outer rings in some sort of code? |
Author: | Paul Micheletti [ Fri Dec 08, 2017 10:23 pm ] |
Clay S. wrote: So are the inner and outer rings in some sort of code? Yes indeed ![]() |
Author: | david farmer [ Fri Dec 08, 2017 10:25 pm ] |
bcombs510 wrote: Tell Mr Jacobs I said hello! Wow, big data is powerful stuff. I got John Smith.Brilliant! Sent from my SM-J727V using Tapatalk |
Author: | bcombs510 [ Fri Dec 08, 2017 10:27 pm ] |
david farmer wrote: bcombs510 wrote: Tell Mr Jacobs I said hello! Wow, big data is powerful stuff. I got John Smith.Brilliant! Sent from my SM-J727V using Tapatalk Lol, for whatever reason I got it right off the bat. Paul’s name is on the outer ring. What a fun thing! Sent from my iPhone using Tapatalk |
Author: | violinvic [ Fri Dec 08, 2017 10:36 pm ] |
Marvin Rosette??? |
Author: | Paul Micheletti [ Fri Dec 08, 2017 10:46 pm ] |
As Brad mentioned above, the rings are in Morse code. The red diamond is the "dash" symbol and the white plus sign is the "dot" symbol. A table with morse code can be found on wiki: https://en.wikipedia.org/wiki/Morse_code Outer ring spells out "Paul E Micheletti 17" ( I added the 17 year because I had some more space to fill) Inner ring spells out "Dwight Jacobs", my customer. The Morse code symbols are made from 5 layers of veneer at 0.020" thick each. Glued up, this makes the tiles 0.100" tall which is just the size of the larger teflon inlay strips available from LMI. I glued up the veneer rings with the teflon strip and then pulled it out after it set. It resulted in a perfect channel to tuck these tiny tiles into. Paul M. |
