It is currently Sat Sep 20, 2025 11:21 pm
PostPosted: Mon Nov 13, 2017 1:42 pm
I've run out of the steel neck inserts I like, and so has McFeelys. I'm on a backorder list but they've been OOS for about a month so far, no idea when they'll get more in.
I really hate the brass ones with the slit on top but will resort to those again if I must, but I would like to find some of the hard steel ones with a hex head driver.
McFadden's isn't accepting new accounts, and anything on Amazon that looks temporarily acceptable seems to be in the 7-18$ range...each!
Can anyone point me in the right direction?
PostPosted: Mon Nov 13, 2017 1:48 pm
Last Name: Colbert
City: Anacortes
Do any of these look right?
https://shop.stafast.com/threaded-inser ... d/screw-in
PostPosted: Mon Nov 13, 2017 1:50 pm
First name: Mark
City: Concord
Lee Valley has a large selection and is where I get mine from. Your local hardware store will probably have them also.
PostPosted: Mon Nov 13, 2017 2:22 pm
I just go down to my local Home Depot. In fact I'll be stopping there on my way home tonight.
PostPosted: Mon Nov 13, 2017 2:39 pm
Hey, yeah, the Stafast SK are the ones. Lee Valley and HD only carry the brass ones which I don't like...
Thanks!
PostPosted: Mon Nov 13, 2017 2:51 pm
Of course they're out of stock duh
PostPosted: Mon Nov 13, 2017 2:55 pm
First name: Dan
Last Name: Miller
City: Cape Vincent
Zip/Postal Code: 13618
I always say "if you can't get it from McMaster, they don't make it"
https://www.mcmaster.com/#threaded-inse ... 75j9ylw4tc
Plus, shipping can be so fast that it seems like they sent your order before you placed it. Cost of shipping has always been reasonable from McMaster for me.
PostPosted: Mon Nov 13, 2017 2:59 pm
Ill try McMaster s again, but last time I did they were not accepting new accounts..l
PostPosted: Mon Nov 13, 2017 3:44 pm
Last Name: Colbert
City: Anacortes
Thanks!
Bummer!!
PostPosted: Mon Nov 13, 2017 4:17 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
meddlingfool wrote:
Hey, yeah, the Stafast SK are the ones. Lee Valley and HD only carry the brass ones which I don't like...!
Ed, have a look at this Canadian site:
https://www.globalindustrial.ca/g/fasteners/Threaded-Inserts/thread-inserts-for-wood/E-Z-Lok-Die-Cast-Zinc-Alloy-Hexdrive
I was looking here for some other stuff, but remembered seeing what appeared to be a large assortment of threaded inserts.
PostPosted: Mon Nov 13, 2017 4:23 pm
Thanks Tim,
Unfortunately those are not the right kind...
PostPosted: Mon Nov 13, 2017 4:30 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
meddlingfool wrote:
Thanks Tim,
Pity — that site is the most diverse of any fastener supplier I’ve come across in Canada.
We’ll be keen to know how you finally source these.
PostPosted: Mon Nov 13, 2017 5:13 pm
They kind I like are hex insert hard steel. They had hex head zinkmfor soft wood, and slot top hard steel, so not quite right.
Happily, however, McMasters was indeed open to taking an order, which took all of 5 minutes by phone, and they even cover the brokerage, so Yahtzee!
Thanks, folks:)
PostPosted: Mon Nov 13, 2017 5:53 pm
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
What size inserts are you all using? Thinking about going this way, too.
Tony Thatcher
Bozeman, Montana
PostPosted: Mon Nov 13, 2017 7:12 pm
I'm using first down under steel...Image
PostPosted: Mon Nov 13, 2017 7:23 pm
Try a company named fastenall. They have nearly every type of fastener you can think of. (Now watch... they won’t have the one you need)
PostPosted: Mon Nov 13, 2017 9:07 pm
They don't...:)
PostPosted: Mon Nov 13, 2017 9:48 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Stafast products Canadain Mississauga
PostPosted: Tue Nov 14, 2017 12:23 am
Stafast out of stock...
PostPosted: Tue Nov 14, 2017 1:46 am
I got my last batch from 'Rockler'.
PostPosted: Tue Nov 14, 2017 11:57 am
I prefer the zinc inserts with the broken thread. I think the bite a little deeper into relatively soft hardwoods like walnut and mahogany.
PostPosted: Tue Nov 14, 2017 2:03 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Stepping back from the choice of which threaded insert..........my question would be why use threaded inserts? I have had problems of them stripping out of the end-grain in the neck, as have other people. Perhaps your hardware or technique are better than mine, but it just seems like a sub-optimal method to me. I use barrel bolts inserted in a hole drilled up from the heel. Even stronger is the method described in the Gore/Gilet books. They cut a square channel up from the heel and inserting a square-profile brass tube, into which there are threaded holes for the bolts. That method seems completely bullet-proof, but I am not tooled up to cut the square hole.
PostPosted: Tue Nov 14, 2017 2:16 pm
I want the bolts to be a softer material than the inserts. If, in the unlikely circumstance either needs to be replaced, I want it to be the bolt, which can simply be replaced, rather than the insert, the replacement of which would be quite the chore...
PostPosted: Tue Nov 14, 2017 2:28 pm
Because if you get the right threaded insert your problems with them more or less disappear.
I'm not too concerned with 'stronger', it only needs to be 'enough' strong to hold the neck immobile under string tension.
Definitely the G/G method is the best, but, at 1599 base, not really practical for me.
If you're worried about the inserts stripping the endgrain, you can drive a 3/4" dowel up through the heel and put the inserts into that, which I have done in the past both as a preventive object in soft Spanish cedar, and as a restorative effort in same. In Khaya, my main neck wood these days, it simply isn't a problem.
Having gone from dovetail, to M&T, to double M&T, to bolt on butt joint with glued tongue, I don't find the last system subpar by any means at all. I had first considered it that myself, and had intended only to use it on my budget line, but once I saw how excellently it works, it's now my only neck joint.
When my base price for the fancy stuff is 5k$, I'll consider moving to the 'better' method in the G/G books, but even then not so much because I think the extra work yields a practical payoff, but so I can point to it as part of why it's 5k$.
These users thanked the author meddlingfool for the post: Bryan Bear (Tue Nov 14, 2017 3:14 pm)
Users browsing this forum: Dmaxwell and 50 guests
