It is currently Sat Jul 19, 2025 8:04 am
 Post subject: Quick Menzerna question
PostPosted: Sat Aug 26, 2017 4:56 pm
Hey people. Looking for a bit of assistance. I have some Menzerna polishes that I have had for a while. Can someone tell me if the old #18 polish is finer or courser than the new P204. And where does #16 fit in to all of that?
PostPosted: Sat Aug 26, 2017 5:08 pm
I think I may have found the answer. P204 may have replaced #18. Both are a bit courser than #16.......I think....;-)
PostPosted: Sat Aug 26, 2017 5:09 pm
Will this help http://www.thepolishingshop.co.uk/acatalog/Menzerna_polishing_compounds_for_woods_plastics_and_lacquers.html
PostPosted: Sat Aug 26, 2017 10:11 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Menzerna products are the best I've found. Likewise their customer support. Their product #s and product descriptions seem to be a secret code that defy the CIA and Wikileaks.
W16, P204, 480W, ATOL6, G35T. 113GZW. Gi5B, 113GZW, WTF!?
I don't pretend to being a buffing adept. Joe White, please weigh in.
Absent Joe. call Menzerna. I've been skeptical of their advice. That was my mistake. They know the business.
Buy some fretwire while you're on the phone. That's another business they understand.
These users thanked the author Eric Reid for the post: James Orr (Mon Aug 28, 2017 12:25 am)
PostPosted: Sat Aug 26, 2017 11:29 pm
Shane, you have it right. The #18 is gone and currently the P204 (salmon color) has taken its place. The #16 is finer than the old #18 or the new P204. Even finer yet is the P175 or Atol6.
jw ( o)===:::
PostPosted: Sun Aug 27, 2017 3:19 pm
Thanks Joe. do you find the need to go finer than 16?
PostPosted: Sun Aug 27, 2017 11:48 pm
Yes I do Shane but I'm not satisfied with the P175.
jw ( o)===:::
PostPosted: Mon Aug 28, 2017 6:36 am
First name: Gary
Last Name: Leddington
So, given the new numbering system... what compounds do you good foks use and in what order?
Thanks.
G.
www.leddingtonguitars.com
PostPosted: Mon Aug 28, 2017 8:25 am
Online
First name: Brad
Last Name: Combs
Thanks.
G.
If the numbers haven't changed again recently, I use this order recommended by Brian Howard a couple years back: 113GZ, P204, GW16, ATOL6. It has worked well for me on water based finishes like Endurovar. I can't say how it would work on other finishes but I believe Brian used it on several finish types.
Brad
These users thanked the author bcombs510 for the post: Colin North (Mon Aug 28, 2017 11:06 am)
PostPosted: Mon Aug 28, 2017 11:41 am
First name: Gary
Brad
I do almost the same but minus the 113GZ and p175 in place of atol6...
Up to what grit to you wet sand before moving to 113GZ?
PostPosted: Mon Aug 28, 2017 11:50 am
Online
First name: Brad
Last Name: Combs
600 usually. Brian mentioned only going to 400 I think but he has skills and I do not. laughing6-hehe
PostPosted: Mon Aug 28, 2017 12:06 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
What annoys me is that the Menzerna bars I purchased some time ago through Stewmac have no numbers/codes written on them -- zilch, not even Stewmac product numbers. So those funny numbers, old or new, as still Greek to me.
PostPosted: Mon Aug 28, 2017 1:35 pm
I have/do what LMI used to recommend:
-Sand to 1000
-then #16 (olive) fine
-then #175 (cream) ultra fine
Worked great on ktm9 (water base) and nitro. BTW if anyone in the Seattle area wants to split them with me or third them even, that would be great as I've used them on a few guitars and probably not even used 1%! Let me know...I could even mail them.
PostPosted: Tue Aug 29, 2017 12:06 pm
Is anyone successfully using different grits on the same buff?
It would sure be nice to not do so much sanding, but not really enough room for a 4 wheel setup...
PostPosted: Tue Aug 29, 2017 12:17 pm
Easy and quick to change buffs, that's what I do when using more than 2 compounds.
These users thanked the author Colin North for the post: Pmaj7 (Tue Aug 29, 2017 12:53 pm)
PostPosted: Tue Aug 29, 2017 1:47 pm
Online
First name: Brad
Last Name: Combs
I also change the buffs, but what I got into the habit of doing is setting up like this:
Buff 1&2, then swap 1 for 3 in case I need to go back to 2 on a spot. Then swap 2 for 4 and that way I can go back to 3 if needed. I read that here or somewhere and it's helpful to minimize the time spent swapping buffs. Seems obvious, but it has been helpful.
Brad
These users thanked the author bcombs510 for the post: Pmaj7 (Tue Aug 29, 2017 3:07 pm)
