It is currently Tue Aug 05, 2025 11:48 pm
PostPosted: Sat May 13, 2017 2:32 pm
I'm making a Manzer wedged cutaway, and know I will face a challenge when it comes to getting square, even depth binding ledges all the way round on the back.
I'm thinking a shop made scratch stock to even up the bottom of the binding ledges, cut first by my tower routing jig.
Looking for suggestions, especially pics, of one someone has used, or seen on the net - I've had no luck so far.
(EDIT)
I just remembered seeing something about evening up binding ledges with a wheel gauge. Like a wheeled marking gauge I think - anyone got details/pics?
PostPosted: Sat May 13, 2017 3:19 pm
What is a scratch stock?
Do other people doing wedges with cutaways encounter problems?
Why do you think it will be a problem?
PostPosted: Sat May 13, 2017 4:03 pm
Last Name: Howell
City: Atlanta
State: Ga
I too have thought of this. I made a tool to score the top. Got it from a youtube video, but design similar to what is shown many places. It suggested turning the blade, made from a saber saw blade, upside down and grind a scraper on it.
PostPosted: Sat May 13, 2017 4:31 pm
A scratch stock is a woodworking tool used for applying decorative treatments, such as beads to furniture and other wooden items. They consist of a handle of some kind, with provision to clamp a steel blade into which the profile of the shape to be cut has been filed (rectangular in my case) and you scrape (scratch) rather than cut, the unwanted wood away.
e.g. https://www.youtube.com/watch?v=G7BJQjuDVgU
Why do I think it will be a problem? -
Using a tower binding router, (and other types) with a doughnut riding on the back and the cylindrical nature of the bottom of the cut by the router bit there are variations in both the depth of the ledge cut and the shape of the binding ledge bottom (slightly curved instead of flat)
This is due to both variations in angle at which the domed back meets the sides at different points around the rims, and the router cutter leading, or trailing, the point of contact of the doughnut with the back, both of which will be much accentuated with a wedge.
PostPosted: Sat May 13, 2017 7:56 pm
We tossed out donuts, and instead use a shop made widget whose high point is right next to the cutting edge of the blade. This greatly helps with keeping the channels even.
What do other people that do wedges do?
PostPosted: Sat May 13, 2017 8:22 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Colin, you can use old saw blades, card scrapers or a wide bandsaw blade.
FW has a couple of articles in the archive on this very topic.
B
PostPosted: Sat May 13, 2017 11:57 pm
I've done one wedge and I had a dickins of a time with the back binding. I finally cut the inside corner of the binding all the way around until it would go in good.
Ed, got a pic of that widge?
PostPosted: Sun May 14, 2017 12:25 am
Tomorrow...
PostPosted: Sun May 14, 2017 4:25 am
[quote="pat macaluso"]I've done one wedge and I had a dickins of a time with the back binding. I finally cut the inside corner of the binding all the way around until it would go in good.quote]
That's something I do routinely on non-wedge bodies (and many others form the posts I've seen on the subject)
Also I ground a small file end and used it as a scraper to help level the bottom of the ledges.
But even then depth variations are still slightly noticeable when binding, especially the back near the neck block.
PostPosted: Sun May 14, 2017 4:40 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We use a Titemark cutting gauge or a Veritas wheel gauge to even out channel depth after milling. On a tapered body, binding jigs that reference depth off the top or back with a donut guide assembly will mill a progressively shallower channel as the angle of the local top/back referenced to the jig's horizontal increases. For most guitars, this means that the back binding channels from neck to about 2" past the waist will be noticeably shallower if not adjusted. The Titemark is the easiest to set and use, but a relatively expensive (but very well made) tool compared to the Veritas or similar knock-off wheel gauges.
We don't worry about the cutter not being square to the sides during the cut - the error is small and the binding edges are beveled, so we get a clean, tight fit.
- Beth Brower
These users thanked the author Woodie G for the post: Colin North (Sun May 14, 2017 7:06 am)
PostPosted: Sun May 14, 2017 7:06 am
Thanks Woodie!
PostPosted: Sun May 14, 2017 4:02 pm
If anyone's interested, found a simple scratch stock for this purpose here http://www.sawmillcreek.org/showthread.php?148247-A-simple-guitar-binding-scratch-stock-G-Wilson
