It is currently Wed Aug 13, 2025 12:56 pm
 Post subject: Fret on a curved end?
PostPosted: Mon Apr 03, 2017 2:40 pm
Hi
I have put a curve shape on the end of the fretboard that I seen on a Google photo and liked
Can anyone give me any advice on shaping the fret end to match the curve
Attached a pic Image
Sent from my D6603 using Tapatalk
PostPosted: Mon Apr 03, 2017 3:08 pm
Last Name: Kincheloe
I shape it before installing, by dragging on a diamond stone or diamond crowning file, followed by sandpaper and micromesh. But do be careful to line it up correctly when installing. This one ended up just a hair too far to the right, so a bit of slot is visible. Better than overhanging and being easy to pull out, but still a bit ugly. The plan was for the other end to be a bit farther from the board edge than the rest, so as to be less snaggy on fingernails if you happen to run into it when picking near the fingerboard. But apparently I forgot and positioned it based on the board edge to match the one above it, and didn't check the curved end before hammering it in. Oh well.
These users thanked the author DennisK for the post: cablepuller1 (Mon Apr 03, 2017 3:25 pm)
PostPosted: Mon Apr 03, 2017 4:47 pm
State: West Somerset
Country: UK
Trevor Gore suggests installing a full fret before shaping the end of the fretboard then cutting the shape using the bandsaw which will happily cut the relatively soft fretwire. I have used this technique very sucsessfully on a couple of guitars. A bit of work with a file to tidy the sharp edges sorts it
I must say I like the look of this sort of termination of the fretboard.
PostPosted: Mon Apr 03, 2017 6:52 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Maybe it's the lighting and camera angle.... those slots look huge. What about binding the whole thing? Then all you gotta do is shape the overhang
PostPosted: Mon Apr 03, 2017 7:17 pm
The end isn't bound, that's a shadow. Fooled me at first.
Sent from my SM-G930V using Tapatalk
PostPosted: Mon Apr 03, 2017 8:32 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
A dremel with sanding drum makes quick work, followed by needle files....sorry, no pics....
These users thanked the author powdrell for the post (total 2): Colin North (Tue Apr 04, 2017 4:52 am) • cablepuller1 (Tue Apr 04, 2017 12:35 am)
PostPosted: Tue Apr 04, 2017 12:37 am
Hi thanks for all the tips. Slots are okay. I have opened up the tops with a triangle file, so look bigger
PostPosted: Tue Apr 04, 2017 9:22 am
I do classical guitars that way and just get it real close and finish it off with files and paper.
These users thanked the author jfmckenna for the post: cablepuller1 (Tue Apr 04, 2017 10:43 am)
Users browsing this forum: dofthesea, doncaparker, meddlingfool, Woodie G and 31 guests
