Bulk Shell Cutting
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=49192
Author:  Andy Birko [ Wed Mar 29, 2017 7:12 pm ]
Post subject:  Bulk Shell Cutting
Hi all,
I'm finding myself using more and more Abalam for client inlay. In the past, I've just been using my bandsaw that I use for wood to cut the sheets to the size I need and I didn't really worry too much about it but I'm finding that shell is much worse for the blades than I had anticipated.
I'm looking for suggestions on something relatively cheep that I can buy to cut these sheets to size that also has relatively cheap blades. My thoughts so far are either a cheapie scroll saw or one of those tiny band saws, 9" that sit on a table top.
9" Band saw is front runner now because I already have an ancient dremel scroll saw and it works like absolute crap for this purpose and I'm working under the assumption that a modern version of a cheap scroll saw will be just as crappy.
The cut quality doesn't have to be that great but it also can't be absolutely terrible. Thin kerf is good so I don't waste too much Abalam. I'm ok with sacrificing some hardboard as a backer board to prevent chip out on the back side.
Any thoughts?
Author:  Clay S. [ Wed Mar 29, 2017 8:18 pm ]
Post subject:  Re: Bulk Shell Cutting
Why not use your CNC machine and dental burrs?
Author:  truckjohn [ Wed Mar 29, 2017 8:20 pm ]
Small band saws are primarily material wrecking toys.. They are almost useless for doing any actual work that requires any sort of precision. About all they are useful for is light very rough work.
My first thought is a high end scroll saw. I have used a few - the Dewalt units at the local working clube were fantastic. I grew up doing wood working on a cheap dremel/home store scroll saw - and the professional units make it look like a toy. They have plenty of power, great guides, a fully tilting table, variable speed... I used the good ones to cut aluminum and even steel plate and they did great.
Author:  Aaron O [ Wed Mar 29, 2017 9:14 pm ]
For me, inlay and Knew Concepts go hand in hand, if you're doing it by hand. Of course this is a bit pricey, but has as thin a kerf as you want, and blades are disposably cheap.
http://knewconcepts.com/power.php
Of course you can get a non-powered version for a fraction of the cost, but I don't think that's what you were looking for.
Author:  Pmaj7 [ Thu Mar 30, 2017 12:49 am ]
Holy smokes.....that is awesome!
Author:  Colin North [ Thu Mar 30, 2017 4:06 am ]
truckjohn wrote:
Small band saws are primarily material wrecking toys.. They are almost useless for doing any actual work that requires any sort of precision. About all they are useful for is light very rough work. .
Not wanting to be arguementative, but my experience, at least of using a 10" Axminster bandsaw, for 7 years, resawing hardwood (maple, walnut, mahogany, sapele) up to 4" with a bi-metal blade is that I have had no problems with accuracy.
The problem with these smaller bandsaws seems to be the blades. When I changed to using the bi-metal blades, accuracy, finish off the saw and blade life improved tremendously.
I have only ever replaced blades, bearing guides and one set of tyres.
Even resawed a thicker pair of sides to get 2 sets.
Just my $0.02
P.S. Can't say for 9" bandsaws....
Author:  Andy Birko [ Thu Mar 30, 2017 7:20 am ]
I could just use an end mill like I do when inlaying but that doesn't solve the problem. The idea is simply to roughly cut strips of the abalam to prep it for inlay duty. The strips or sheets or whatever you call them are glued to a backer of MDF for cutting the inlay itself. This can be done while the machine is busy with other work.
From what I'm picking up here, it seems like anything decent will be rather pricey. Perhaps burning through bandsaw blades might be the cheapest solution?
Author:  kencierp [ Thu Mar 30, 2017 7:58 am ]
We use inexpensive 9" Delta band saws set up for dedicated operations surprisingly accurate and vibration free. I suggest you send Chris Paulick a message the blades he uses in his videos seem to cut Ablam like butter while leaving a finished edge.
Author:  Rodger Knox [ Thu Mar 30, 2017 1:27 pm ]
I've got an old Craftsman tabletop 3 wheel bandsaw that I use quite a bit for that type of cutting. I think it works fine, but I don't have much experience with really good tools. The max depth is only 3", but that's plenty for abalam.
Author:  Haans [ Thu Mar 30, 2017 4:30 pm ]
These make VERY clean cuts...
http://www.proxxon.com/us/micromot/37070.php?list
Author:  Andy Birko [ Thu Mar 30, 2017 8:02 pm ]
I've found a number of small bandsaws on Craigslist for under $100 so I'm going to give that a try. My guess is it will be good enough.
thanks!
Author:  dzsmith [ Thu Mar 30, 2017 8:37 pm ]
I have a 9" bandsaw fitted with a fine tooth blade.
I ran a thin board into the blade and affixed the board to make a zero clearance insert.
It works great for shell and small thin pieces.
Author:  B. Howard [ Fri Mar 31, 2017 7:47 am ]
Have you thought about a small wet saw? I assume most of your blanks you need are square or rectangular... something like thishttps://www.prosourcecenter.com/product/2306/qep-60089-master-cut-portable-tile-saw-7-inch/?Item=30614&gclid=CjwKEAjw_PfGBRDW_sutqMbQsmMSJAAMpUap447uus2iKAATbxT2qWTh8QXLY0Xc9FWQZezH7qdolRoCBGLw_wcB
Author:  Linus [ Mon Apr 03, 2017 2:10 pm ]
Check out Micro-Mark. They have a small table saw that might do the trick.
