Pre-cat lacquer over normal nitro
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=49191
Author:  jshelton [ Wed Mar 29, 2017 5:51 pm ]
Post subject:  Pre-cat lacquer over normal nitro
I know that pre-catalyzed lacquer must be restricted to no more than 3 coats so has anyone tried building with normal nitro and finishing with a coat or two of pre-cat? It seems like a way to get a fast cure to avoid the long wait for normal nitro to get hard enough to polish. I suspect it won't work since the undercoats would still be shrinking but has anyone tried it?
Author:  B. Howard [ Thu Mar 30, 2017 7:29 am ]
Post subject:  Re: Pre-cat lacquer over normal nitro
Not going to work. The harder precat will wrinkle and crack because you cannot put a harder coating over a softer one.
The restrictions on precat or post cat systems have little to do with number of coats applied. It is about keeping final working films under 5 mills after buffing.Depending on actual solids content and thickness of wet spray you will find that 7 coats is about the actual maximum.
If you want fast cure and harder finish just use a precat for the whole thing.
Author:  jshelton [ Thu Mar 30, 2017 8:24 am ]
Thanks, this is pretty much what I expected. I tried pre-cat on three guitars and ended up refinishing all three due to crazing, swore I'd never use it again.
