It is currently Tue Aug 12, 2025 11:11 pm
PostPosted: Tue Jan 31, 2017 5:22 pm
First name: Brad
Last Name: Combs
Hello,
Recently I came to the conclusion that I'm not ready to carve necks yet. I've built three guitars so far and all three had necks that were too wide at the shoulders (hoping that is the right term) and flat across the back, not rounded. I've already started the process of getting CNC necks going and I'm going to do that for at least the next few builds.
But... not wanting to give up completely on neck carving I bought a template from LMI (two actually, an OM and Dread which coincidentally are almost exactly the same and I'm not sure why they sell two different parts). Below are some pics of the template held to a neck for a parlor I completed recently. The parlor is finished with tung oil which makes me wonder if I can make some adjustments to the neck and improve the feel of it.
Any thoughts on this? Just take the shoulders down with a rasp and try to fit to this template? Leave well enough alone? As an aside, this guitar is the best sounding so far. I must be learning a little something. ;)
Appreciate any feedback.
Thanks!
Brad
PostPosted: Tue Jan 31, 2017 5:34 pm
Last Name: McGlynn
City: Scotts Valley
Zip/Postal Code: 95066
Personally I'd leave the finished guitar alone unless it's so uncomfortable you don't want to play it. You certainly *could* re-shape it and re-finish it.
Blog on Making Stuff: http://www.McGlynnOnMaking.com
These users thanked the author JoeM for the post: bcombs510 (Tue Jan 31, 2017 5:40 pm)
PostPosted: Tue Jan 31, 2017 5:43 pm
State: Tennessee
bcombs510 wrote:
Hello,
Thanks!
Brad
If your playing it I'd leave it alone, Get some cheap wood, a neck/pattern you really like and let the shavings fly. I use Stew Mac Dragon, and Liogier rasp, a Veritas spokeshave and several straight edges. Get the area under the first, and the 11/12th fret right and its easy to blend it all together. Practice makes perfect.
These users thanked the author Clinchriver for the post: bcombs510 (Tue Jan 31, 2017 6:11 pm)
PostPosted: Tue Jan 31, 2017 6:01 pm
Last Name: Kincheloe
Go for it. Nothing wrong with continuing work on the neck after it's attached to the box. And it does make a big difference in comfort when you get the shape right. Don't be a chicken, but don't be careless either. You can always take more off later, but you can't put it back. Focus more on the feel of it than the visual match to the templates.
These users thanked the author DennisK for the post: bcombs510 (Tue Jan 31, 2017 6:11 pm)
PostPosted: Tue Jan 31, 2017 7:43 pm
I do it like Clinchriver states above. Get the 1st fret and as far up as you can go without running into the heel using templates, then blend the rest. I usually do this over a few day's here and there so I can look at with a fresh set eyes as I'm working. Look at it under varying light and inspect it by feel. You should be able to get great results this way.
These users thanked the author Jim Watts for the post (total 3): Clinchriver (Wed Feb 01, 2017 4:29 am) • Alex Kleon (Tue Jan 31, 2017 8:41 pm) • bcombs510 (Tue Jan 31, 2017 8:04 pm)
PostPosted: Tue Jan 31, 2017 7:46 pm
I re-carved one of the early made necks and was very happy with the results, it was finished with lacquer so it required a lot more touch in the refinishing department than yours might.
It's hard to tell from the pictures whether your necks are thick enough for a total reshaping, but as long as it's not too thin already I would definitely take some off the sides. A benefit would be if you are carefull you could shape it, tighten the strings and play it for a little while and then adjust it more if needed.
These users thanked the author kjaffrey for the post: bcombs510 (Tue Jan 31, 2017 8:05 pm)
PostPosted: Tue Jan 31, 2017 8:19 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
It's an example of your work/art. Build the next one remembering what and how someday you might want to look back on this one. Good luck[SMILING FACE WITH SMILING EYES]
These users thanked the author Lonnie J Barber for the post: bcombs510 (Tue Jan 31, 2017 9:36 pm)
PostPosted: Wed Feb 01, 2017 12:31 am
City: Escondido
Zip/Postal Code: 92029
Add me in to the "go for it" crowd. My third guitar had such a sweet voice, but like a lot of beginners I just didn't understand how much wood you remove to go from a square neck blank to a good playable neck. It had that characteristic "school bus" profile. I kept wanting to play it, but that neck would make me put it down.
Finally, almost a decade later, I decided if I destroyed the neck by re-carving it I could live with that. She wasn't getting played anyway. I carved it, sanded and prepped it, and refinished it in a couple of days. WHAT A DIFFERENCE! I love playing this guitar now, and I love handing it to friends to play. I wish I had done that years ago.
So I say "go for it". It's not set in stone. Make it right for you!
These users thanked the author rlrhett for the post: bcombs510 (Wed Feb 01, 2017 6:09 am)
PostPosted: Wed Feb 01, 2017 12:57 am
First name: doug
Last Name: powdrell
City: hilo
State: big island
I have 'fine tuned' several necks after they were completed and played.....mostly around the 1-3 frets. Let your left playing hand be the judge....a small amount taken off can make a BIG difference. Your hand is a better judge than a template...my $.02......
These users thanked the author powdrell for the post: bcombs510 (Wed Feb 01, 2017 6:10 am)
PostPosted: Wed Feb 01, 2017 1:10 am
This is funny to me in an ironic sense. I just finished my first neck today after purchasing pre-made necks up until now. I used the Victor neck template from Luthier Suppliers (after the builder of my favorite neck at the Santa Barbara show told me he used the 2006 Taylor Concert template from Luthier Suppliers, I ordered one of those as well), a course and medium rasp from Lioger, a spokeshave, and sandpaper.
I loved using the spokeshave and rasps, but the most useful tool turned out to be sandpaper. I used a spent roll of 100 grit paper from my drum sander to do the final smoothing along the shaft, and a few of the drums from my spindle sander to blend shaft to headstock and shaft to heel transitions after rasping away as much as I could.
I think you should go for it. Err on the side of being careful rather than careless, and work in specific sections at a time. The neck template page on the Luthier Supplier's website has a link to some detailed videos on the process.
These users thanked the author James Orr for the post: bcombs510 (Wed Feb 01, 2017 6:11 am)
PostPosted: Wed Feb 01, 2017 2:16 am
Last Name: Beaver
City: Lake Forest
When you are laying out a neck for shaping, there are two two planes you need to establish first, then make sure you don't change those during shaping.
The first is the sides of the neck that are dictated by the shape of the fingerboard, and the second is the flat plane down the center of the bottom of the neck that is determined by the thickness you want under the nut and at the place the where the transition to the heel begins. Establish those planes first then round almost to them, but never change those surfaces as you shape.
In your pictures with the template, check the thickness of the neck at the two points. If you are already there then you can only do a little shaping on the sides of the neck without changing the intended plane. Also make sure the width of the fingerboard at the nut and body joining fret are the same on the template as the neck you are making. For instance, Most of my necks are 1-3/4 and 1-13/16" at the nut. A template design for a 1-11/16" nut would throw me off.
It's late here. I hope this still makes sense in the morning. Good luck
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: bcombs510 (Wed Feb 01, 2017 6:13 am)
PostPosted: Wed Feb 01, 2017 8:56 am
Last Name: Cox
Go for it. I have reshaped necks on guitars... Finishes can be replaced... And if it's your guitar - you probably still have the original finish laying around so you can redo it.
In this case - there's nothing worse than a neck you hate on a guitar you like.
Neck shaping by hand takes some practice. As others have said - if it looks about right without the fretboard - it's way too chunky.. School bus is a great description of the shape.
It sounds like you aren't after the depth of the neck - but rather flattening out the shoulders.
In real life - I think of the shape of a guitar neck more like half an egg or a parenthesis mark ( than a C or D shape... Which generally feel too fat against your fingers.
My only case for leaving it be is if you have a friend who loves the neck and you give it to him.
These users thanked the author truckjohn for the post: bcombs510 (Wed Feb 01, 2017 9:24 am)
PostPosted: Wed Feb 01, 2017 9:27 am
First name: Brad
Last Name: Combs
This is all good feedback. I appreciate it!
I'm going to give it a shot. My plan is to use my contour gauge to take a profile of the neck, compare that to the template (I'll just use the OM template to get it "close") and determine what material needs to come off. Heard loud and clear, take it slow. Will do that. I'll post of pics of the progress unless I start carving and hit truss rod. :D
I have a couple cheaper rasps and two microplane shapes (rounded and flat). I may invest in some quality rasps first though. So thanks for the suggestions there as well.
Brad
PostPosted: Wed Feb 01, 2017 10:17 am
I've redone one and glad I did. Not a big deal, just take your time. If you screw it up, make a new neck.
These users thanked the author SteveSmith for the post: bcombs510 (Wed Feb 01, 2017 11:05 am)
PostPosted: Wed Feb 01, 2017 11:51 am
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Zip/Postal Code: 95492
Some good advice from people more experienced than me. One concern I've had is to not make the neck thickness too thin at the truss rod near the 1st fret. If you know how deep you made the channel you can measure how much wood remains.
Brad Hall
Mystic Dawg Guitars
These users thanked the author BradHall for the post: bcombs510 (Wed Feb 01, 2017 12:08 pm)
PostPosted: Wed Feb 01, 2017 12:33 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
My necks also tended to be to shaped like what you are showing with the template. I have taken a spokes shave and rasp to three of my early guitars just taking the shoulders down. I created an even facet on both sides then blended the facets in without changing the thickness of the neck. The changes made a huge difference. I refinished with shellac and royal-lac. It was well worth the time and effort.
These users thanked the author johnparchem for the post: bcombs510 (Thu Feb 02, 2017 5:19 am)
PostPosted: Wed Feb 01, 2017 12:50 pm
Powdrell wrote:
"Your hand is a better judge than a template...my $.02......"
Words to live by....
To refine the shape of the neck I would use a card scraper. It can remove a surprising amount of material and leaves a more finished surface than a rasp, and will allow you to feel the shape of the neck better.
These users thanked the author Clay S. for the post: bcombs510 (Wed Feb 01, 2017 12:53 pm)
PostPosted: Wed Feb 01, 2017 11:00 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I might try those templates against a neck that I like to see how they match. Oh, and by the way, go for it.
Ed
These users thanked the author Ruby50 for the post: bcombs510 (Thu Feb 02, 2017 5:19 am)
PostPosted: Mon Feb 06, 2017 10:30 pm
First name: Brad
Last Name: Combs
Thanks for all the replies. I went for it over the weekend and carved the shoulders off and rounded out the feel of the neck. I used the widest part of the template just to visually check as a I moved up the neck. I used a couple files, pictured below. I have to admit the template gave a lot of confidence as I was working.
To my surprise I had to give a slight level and recrown of the frets to get rid of a little buzz in the G and D strings.
I'm very happy with the results. Glad I did it, with the encouragement from you folks.
Thanks!
Brad
PostPosted: Tue Feb 07, 2017 1:46 pm
Great, glad it worked out.
These users thanked the author SteveSmith for the post: bcombs510 (Tue Feb 07, 2017 2:02 pm)
PostPosted: Tue Feb 07, 2017 9:48 pm
Last Name: Marcq
City: Allenstown
Zip/Postal Code: 03275
In my vast neck carving experience (like, 6), this is what I've learned: When you are cruising right along, rasping, scraping, measuring the thickness, checking the cardboard templates you made, checking how it feels in your hand, when you finally think you have it just right, you should have stopped 5 minutes earlier. Now, when I get it close, I leave it and come back the next day, fresh eyes, different light, whatever. Sculpting, or whatever this is, I'm definitely a plodder, not a natural...
These users thanked the author Steve Marcq for the post: bcombs510 (Tue Feb 07, 2017 10:10 pm)
PostPosted: Tue Feb 07, 2017 11:01 pm
Looking at a newly shaped neck the next day with fresh eyes and hands seems a common theme with experienced builders. Maybe even over a couple of days.
It's a very important part of my neck shaping process.
It is surprising how blending the curve of the neck into the fretboard so it is a continuous arc makes such a big difference in playability.
These users thanked the author Terence Kennedy for the post: bcombs510 (Wed Feb 08, 2017 6:20 am)
PostPosted: Wed Feb 08, 2017 8:17 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Spokeshave, chisels, rasps, scrapers, sandpaper like everyone else.
I've been very happy with this 12" hand cut rasp from The Best Things shown next to an original Nicholson #50 which is also very good. I also use a couple smaller ones around the heel & where the neck meets the peghead.
http://www.thebestthings.com/newtools/h ... _rasps.htm
I'm not a luthier.
These users thanked the author klooker for the post: bcombs510 (Wed Feb 08, 2017 10:18 am)
PostPosted: Wed Feb 08, 2017 9:40 am
I'm glad you went for it, I've done that very same thing on a couple guitars and it's made a great difference. As for carving, I've never used any templates for measuring profiles, it just seems unnecessary to me and even a bit cumbersome. Last year I got those Dragon rasps that Stew Mac sells and that was a great investment. I used to use knives and chisels to get the heal and nut end right but man those wrasps make it easy and fast. Once the two ends are made then I pull everything together with the spoke shave. The spoke shave is great becasue it keeps everything even. All you have to do is watch the curl and then you know it's an even cut.
Cumpiano and Natelsons book has a great tip on carving the neck that I have used since I got that book many many years ago. Hold it up to a window or a very bright light and look for the edge of light on the curved profile of the neck along it's length. If it's a nice straight shado line then you know you are getting it right.
I always finish off the profiling nad remove the spoke shave tool marks with a radius sanding block.
These users thanked the author jfmckenna for the post: bcombs510 (Wed Feb 08, 2017 10:19 am)
