It is currently Wed Aug 13, 2025 10:21 pm
PostPosted: Sat Dec 17, 2016 10:40 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
In the past I was using a soundhole patch of either spruce at 2mm.080 or WRc at .100 or 2.5mm. no rosette on the ukes. It was usually vertical grain running at 90 deg to the top . lately I have switched to using a thin birch 2-2.5mm or poplar ply for the S. patch on my ukes to accamodate the rosette design . what are you using .?? I find the ply makes for a more solid area around the top so that there is less flattening of the area before gluing down the FB .
PostPosted: Sat Dec 17, 2016 1:07 pm
I used a reinforcing patch for the first time on this guitar and used cut-off from the top.
PostPosted: Sat Dec 17, 2016 1:56 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I join the cutoffs from the waist aria to make a sound hole patch. So it basically doubles the top thickness around the sound hole.
PostPosted: Sat Dec 17, 2016 3:51 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks , thats what I/ve done as well using cutoffs from the top .But nowI find using uber thin plywood is more to my liking. and gives me a flatter area under the FB and UTB. Is anyone else using thin plywood as a soundhole patch ??
PostPosted: Sun Dec 18, 2016 8:38 am
For the last uke I made I used two layers of the top material (off cuts) alternating the grain (essentially "plying" the wood ) as soundhole reinforcement. The top itself is just over 1/16th inch thick.
These users thanked the author Clay S. for the post: ernie (Sun Dec 18, 2016 9:14 am)
PostPosted: Sun Dec 18, 2016 1:06 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I am in the process of French Polishing this Soprano now, trying to finish it up for a Christmas present.
The top on this is .065 and I added a sound hole patch of .050, set cross grain at 90 degrees and made from 1 of Shanes' Lutz Spruce 2nds.
Hoping to have it strung up by end of the week
These users thanked the author Tim L for the post: ernie (Sun Dec 18, 2016 4:11 pm)
Users browsing this forum: DennisK, meddlingfool and 27 guests
