New Luthier Tips du Jour video - radiusing braces http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=48674 |
Author: | Robbie O'Brien [ Mon Dec 12, 2016 9:31 am ] |
Post subject: | New Luthier Tips du Jour video - radiusing braces |
Here is the latest Luthier Tips du Jour video - In this video I share some ideas about how to radius braces. This video as well as all my other videos are available via my website, http://www.obrienguitars.com/videos , LMI's website or on youtube. |
Author: | kencierp [ Mon Dec 12, 2016 9:51 am ] |
Post subject: | Re: New Luthier Tips du Jour video - radiusing braces |
Just say-in -- this method is hard to beat, takes less than a minute per brace. |
Author: | REvans [ Mon Dec 12, 2016 10:28 am ] |
Any one besides me have a concern over a sanded surface at the brace/top joint? I always refine the surface with a plane before i glue it down. |
Author: | SteveSmith [ Mon Dec 12, 2016 10:44 am ] |
I've done it both ways but I cut mine with a plane now. None of the sanded joints have come apart so far. |
Author: | jfmckenna [ Mon Dec 12, 2016 11:26 am ] |
LOL... I like the self sanding part that's somthin' else! I just use a plane too. Once you rip of a full length paper thin curl you are done. I don't think that sanding vs planing makes a difference though, on paper yes a physicist can show that a planed surface is better but... |
Author: | Glen H [ Mon Dec 12, 2016 3:25 pm ] |
When I first started out, I had a jig for everything and probably 3 different ones for arching braces. I figured out that in some cases the jig solves a problem but isn't much better than without the jig. I just use a plane. But, if it helps, then use it. |
Author: | Clinchriver [ Mon Dec 12, 2016 5:41 pm ] |
I use a planed edge, method is a combination of Marios and Bruce Sexauer. While my Veritas Shoot board plane might be overkill the results speak for themselves. |
Author: | ernie [ Tue Dec 13, 2016 8:24 am ] |
I use a plane and then LMI sanding jig, except I use 120 grit on the jig . either way will work |
