It is currently Fri Aug 15, 2025 2:08 pm
PostPosted: Mon Aug 29, 2016 8:46 am
Here is the latest Luthier Tips du Jour video - In this video I talk about how to use Friendly Plastic from LMI.
This video as well as all my other videos are available via my website, http://www.obrienguitars.com/videos , LMI's website or on youtube.
PostPosted: Mon Aug 29, 2016 9:08 am
Last Name: Kincheloe
Yep, it's good stuff [:Y:] Feels like cheating. Totally reusable, too. And it carves nicely, if you need to make any modifications after it's cooled.
This is a good way to make a bridge caul if you use different shapes all the time like I do, and especially if the bridge thickness is tapered toward the back edge, which unbalances the clamping pressure (makes it want to slide forward). The plastic will form to grip the bridge pin holes so it can't slip.
And you don't necessarily need a lot of plastic. Rather than making an entire caul out of it, you can use a flat or roughly shaped wood block, and just enough plastic to fill the gaps between that and the target object.
PostPosted: Mon Aug 29, 2016 10:47 am
Better than using bondo....
