Rosette circle cutters
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=47948
Author:  dofthesea [ Mon Jun 27, 2016 1:29 am ]
Post subject:  Rosette circle cutters
Just wanted to share this. A guy over on the UU forum is offering a Rosette cutter guide with 1/8" and 3/16" registration pin holes. all for $8 plus shipping a steal. Wide should try to convince him to do a guitar size guide as well.
Scroll down towards the bottom of the posts.
http://forum.ukuleleunderground.com/sho ... cle-cutter
Author:  Colin North [ Mon Jun 27, 2016 4:59 am ]
Post subject:  Re: Rosette circle cutters
1/10th " steps are no use to me, sorry.
I'll stick with my wells-carol.
Author:  dofthesea [ Tue Jun 28, 2016 3:39 am ]
Collin for some reason I was having a blond moment. Your absolutely correct on that comment. It also isn't adjustable.
Author:  jfmckenna [ Tue Jun 28, 2016 7:16 am ]
But in his case it seems to work fine. If you want to remain consistent from rosette to rosette and build them the same for each one and it fits within your paradigm then it's probably a very useful tool.
Author:  SteveSmith [ Tue Jun 28, 2016 9:15 am ]
Biggest problem I see is that you cannot move the bit incrementally to open up a channel. As long as an exact bit size works at the available radii than that would be ok.
