Bending herringbone
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=47814
Author:  cablepuller1 [ Tue May 24, 2016 3:55 pm ]
Post subject:  Bending herringbone
Hi
Going to be using herringbone purfling for the first time..
Anyone got any tips for shaping to body?
Should I use it dry on bending iron or soak it and try and shape it
Author:  johnparchem [ Tue May 24, 2016 4:19 pm ]
Post subject:  Re: Bending herringbone
I dry bend it on an iron, maybe a spritz of water. If it is made by Gurian Instruments, I find it is easy to bend without delaminating. It does want to twist bending it on edge, but I still find it manageable. I know, at least at one time, Gurian supplied a lot of the lutherie outlets.
Author:  kencierp [ Tue May 24, 2016 4:57 pm ]
Author:  mqbernardo [ Tue May 24, 2016 5:00 pm ]
i make my own herringbone and use Titebond 3. even with TB3 i prefer not to use water while bending it. what i found helpful was wrapping the HB in aluminium foil. It doesn't need much heat to bend, i keep my ibex iron around 4 (IIRC). of course it helps if it´on the thin side.
good luck!
miguel.
Author:  Nils [ Tue May 24, 2016 7:00 pm ]
Using my router, I cut a channel to the shape I want (the channel depth is slightly less than the thickness of the purfling) and then use a clothing iron (no water) to make it take the shape of the channel. I then press it in the channel for like 15 mins with a piece of plywood or something.
Author:  Michael [ Tue May 24, 2016 7:44 pm ]
I have done this many times. Soak for 10 minutes and bend to form. Let dry and that's it.
Michael
