It is currently Fri Aug 15, 2025 7:01 am
PostPosted: Mon May 16, 2016 1:27 pm
Here is the latest Luthier Tips du Jour video - In this video I talk about how to help keep the centerline of the back on center when closing the box.
This video as well as all my other videos are available via my website, http://www.obrienguitars.com/videos , LMI's website or on youtube.
These users thanked the author Robbie O'Brien for the post: Pmaj7 (Tue May 17, 2016 12:49 am)
PostPosted: Mon May 16, 2016 2:08 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Great tip, Robbie! If you don't have a drill bit that matches the nail, clip the head off of a finish nail, chuck it into the drill, and use it as a drill bit for your pinning nail.
Alex
PostPosted: Mon May 16, 2016 2:29 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
A great method that I will use, I had a friend who really goofed up the alignment once or maybe twice.
Alex
Conversely, If you do not have a matching pin or nail for the hole you drilled turn the bit upside down and use it for the pin
PostPosted: Mon May 16, 2016 3:54 pm
First name: Tom
Last Name: West
State: Nova Scotia
Robbie: Super Idea..............!! Thanks for that..!!!
Tom
PostPosted: Mon May 16, 2016 3:57 pm
First name: Tom
Last Name: West
State: Nova Scotia
Alex
Alex : I do this when drilling holes in fret slots for locating fingerboard. Works a treat...!!
Tom
PostPosted: Mon May 16, 2016 4:24 pm
City: Tyler
One of those "why didn't I think of that?" moments!
PostPosted: Mon May 16, 2016 8:32 pm
I always save my broken 1/16" bits and use them as pins after I drill the hole.
PostPosted: Tue May 17, 2016 12:49 am
WDITOT
PostPosted: Tue May 17, 2016 8:41 am
Last Name: Lazar
City: St. Albert
State: Alberta
Zip/Postal Code: T8N 5Y6
dang...that is a good one :o
PostPosted: Tue May 17, 2016 8:48 am
The 1.4mm finishing nails at Ace fit a 1/16" bit as well. Great for headstock veneers too.
PostPosted: Tue May 17, 2016 9:03 am
McMaster Carr sells dowel pins. About 6 years ago I bought some in 1/16", 1/8", and 3/16" in stainless steel. I'm still using and re-using the original pins that I removed from the bags. I use the 1/16" for locating fret boards, 1/8" when attaching tops/backs and head plate layups. Sometimes I use the 3/16" to locate bridges.
I put some wax on them and they release easy - heck, they release easy when I forget and don't put anything on them :)
PostPosted: Tue May 17, 2016 11:41 am
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Robbie - I close the box with the back (or top) sitting on the radius dish underneath the rims using the dish as a caul for clamping which means that I can't have the pin sticking up above the surface of the back. Do you know of a similar clever way to pin the back when closing the box this way?
I suppose I could pin it as in the video and then cut the nail flush with the surface, but then removing the block afterwards might be a bit of a hassle since the nail couldn't be pulled out.
PostPosted: Tue May 17, 2016 1:23 pm
If you let the brace ends into the linings doesn't that keep it all held into place?
PostPosted: Tue May 17, 2016 1:45 pm
First name: Jay
City: Bothell
State: Washington
Yes, they do a good job of holding it all in place so I haven't had problems getting everything lined up where I want it as long as I pay close attention along the way. The ladder bracing on the back holds the back in position fine lengthwise, but I do get just a bit of free play (1/16") side-to-side. It seems that a pinning method that's as simple as the one Robbie showed would be easy insurance for keeping things exactly in position.
PostPosted: Tue May 17, 2016 1:54 pm
Use a toothpick or something similar you could just break off flush and that should do it.
These users thanked the author Robbie O'Brien for the post: J De Rocher (Tue May 17, 2016 7:59 pm)
PostPosted: Tue May 17, 2016 2:08 pm
City: Tyler
I do the same with the gobar deck. I'm thinking of two blocks one on the side, the other on the back and in contact means their lined up. Or the toothpick approach. I'll try one or the other, assuming I ever get back to building another guitar.
PostPosted: Tue May 17, 2016 4:55 pm
First name: William
Last Name: Snyder
City: Brooklyn
Or drill all the way through the block and pin it from the other side.
These users thanked the author WilliamS for the post: J De Rocher (Tue May 17, 2016 7:59 pm)
Users browsing this forum: doncaparker and 21 guests
