Tuner hole "shielding" for spraying
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=47639
Author:  Colin North [ Sun Apr 17, 2016 4:59 am ]
Post subject:  Tuner hole "shielding" for spraying
Any one got any "tricks" to keep tuner holes clear of finish (or minimise it) when spraying?
Or do you generally just deal with it after?
Author:  bcombs510 [ Sun Apr 17, 2016 5:34 am ]
Post subject:  Re: Tuner hole "shielding" for spraying
I've only sprayed a couple of necks so far, but what I did was take a shop towel style paper towel and poke it through and pull until the the hole was tightly filled. Then I took a razor and flush cut it on both sides. They popped out pretty easy after spraying.
I've also seen people talk about using the disposable ear plugs but I haven't tried that yet.
Author:  Clinchriver [ Sun Apr 17, 2016 7:20 am ]
A sharp reamer does a nice job of cleaning up
Author:  Dave Stewart [ Sun Apr 17, 2016 7:35 am ]
I always favoured expandable foam ear plugs .... readily avail at drugstores & perfect for the job
Author:  Chris Pile [ Sun Apr 17, 2016 8:31 am ]
Isn't that why reamers were invented?
Author:  meddlingfool [ Sun Apr 17, 2016 8:46 am ]
I drill the holes after finish. Buffs out easier too.
Author:  Ben-Had [ Sun Apr 17, 2016 10:17 am ]
I always did that as well. My last two guitars I tried drilling them first. I'm going back to my old method because they buff out better for me that way. I should add, I attach my necks after finishing is done.
Author:  dzsmith [ Sun Apr 17, 2016 11:04 am ]
I clean 'em up after spraying, wet sanding, and polishing.
I use sandpaper wrapped around a dowel. Not a pleasant task.
Author:  SteveSmith [ Sun Apr 17, 2016 12:25 pm ]
I just ream em. Just takes a minute.
Author:  J De Rocher [ Sun Apr 17, 2016 1:32 pm ]
I'm another who switched to drilling the holes after finishing.
