New bench, OLF inspirations http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=47596 |
Author: | Rod True [ Fri Apr 08, 2016 1:00 am ] |
Post subject: | New bench, OLF inspirations |
I've been wanting more bench space in my shop for some time now. I seem to change up my shop every year or so, trying to make my 185 sft more efficient with the tools I have and need for more bench space. I recently decided that I'm not going to be finishing my own guitars any more as I have some good local options, this has freed up the far corner of my shop where my spraybooth and fan where located. I decided to make a U shaped bench, inspired by Shane's found in this thread My bench isn't quite as big as Shanes but pretty close. I'm 8 feet along the long run of the wall and the peninsula comes out 4 feet to the vise mount (thanks to Todd Stock with help from Woodie B in this thread), then the vise mount sticks out 8". The deep inside corner of the bench will house my new gobar deck, which will spin so I can access all sides. There are 16 large drawers total (that you can see) and on the left side of the peninsula are two cupboards with adjustable shelves. Right at the end of the peninsular will be 4 drawers that can slide through either side. My plan is to keep set up tools there as well as my barbells for the new binding jig. Just above those drawers on either side will be a 2 socket plug for easy access when routing, drilling, sanding.... I'll post a few more pictures the next time I get in the shop and it's all organized. I did have to move a bunch of stuff around but once again, I feel like I've got more room to move around in my shop (always important) and also have gained 2 new bench surfaces and more storage than before. ![]() ![]() |
Author: | Colin North [ Fri Apr 08, 2016 2:44 am ] |
Post subject: | Re: New bench, OLF inspirations |
Nice one Rod. ![]() |
Author: | jfmckenna [ Fri Apr 08, 2016 8:36 am ] |
That looks real nice and I like what you did there with that vise. I think I may have to do the same thing for my bench. |
Author: | bcombs510 [ Fri Apr 08, 2016 8:39 am ] |
jfmckenna wrote: That looks real nice and I like what you did there with that vise. I think I may have to do the same thing for my bench. When Woodie B posted that for Rod a couple weeks back I built one (not as nice as Rod's ![]() |
Author: | meddlingfool [ Fri Apr 08, 2016 9:49 am ] |
You're just missing the all important floor mats and and a few wipe coats of shellac on the mdf. Really helps keep the surface flat and unlumpy from cans, water glasses, spritz ing from this and that... |
Author: | jfmckenna [ Fri Apr 08, 2016 9:54 am ] |
bcombs510 wrote: jfmckenna wrote: That looks real nice and I like what you did there with that vise. I think I may have to do the same thing for my bench. When Woodie B posted that for Rod a couple weeks back I built one (not as nice as Rod's ![]() Nice! I must have missed that post. Think I will get busy this weekend on it. |
Author: | SteveSmith [ Fri Apr 08, 2016 10:19 am ] |
That's nice Rod. It reminds just how badly I want to redo my shop - again. |
Author: | George L [ Fri Apr 08, 2016 10:21 am ] |
Well done! My workbench needs some TLC. Thanks for the inspiration! |
Author: | Colin North [ Fri Apr 08, 2016 10:32 am ] |
meddlingfool wrote: You're just missing the all important floor mats and and a few wipe coats of shellac on the mdf. Really helps keep the surface flat and unlumpy from cans, water glasses, spritz ing from this and that... Dunno, maybe Z-poxy would pop the grain better? ![]() |
Author: | Rod True [ Fri Apr 08, 2016 1:34 pm ] |
meddlingfool wrote: You're just missing the all important floor mats and and a few wipe coats of shellac on the mdf. Really helps keep the surface flat and unlumpy from cans, water glasses, spritz ing from this and that... I got me a good pair of shoes for in the shop with amazing cushion but I should have a few mats around the bench in case I drop a chisel. Yup, gotta seal that MDF with something, thinking minwax urethane.... |
Author: | meddlingfool [ Fri Apr 08, 2016 6:48 pm ] |
Min wax is what I put on mine too, I guess I was being generic with shellac... |
Author: | dzsmith [ Fri Apr 08, 2016 7:22 pm ] |
Love the vise! I plan to revamp my space soon too. I'm lucky to have a window at my bench. |
Author: | Clay S. [ Sat Apr 09, 2016 7:07 am ] |
"Yup, gotta seal that MDF with something, thinking minwax urethane...." Laminating with Formica would give you an easily cleaned solvent resistant surface. |
Author: | Rod True [ Sat Apr 09, 2016 9:38 am ] |
Clay S. wrote: "Yup, gotta seal that MDF with something, thinking minwax urethane...." Laminating with Formica would give you an easily cleaned solvent resistant surface. Hmmmm, don't know if I'd want a laminate top for my bench..... |
Author: | Rod True [ Sat Apr 09, 2016 3:15 pm ] |
Here's an iPhone pano pic of my shop now. Still 2 small shelves to build but I'm nearly finished this round of reno's ![]() Sent from my iPhone using Tapatalk |
Author: | James Orr [ Sat Apr 09, 2016 4:50 pm ] |
It's really open now. I bet it feels great to have a more flexible and open workspace. |
Author: | Pat Foster [ Sat Apr 09, 2016 5:58 pm ] |
Looks great, Rod. A while back, in a shop thread, I saw your space and wondered, "how does he do it with only 180 sq ft. At the time, I had about 220. Now I'm down to 170, so now I know-you get creative! I have a similar carver's vise. It mounts into the workbench side vise so I can put it away when it's not needed. But when I need it, I REALLY needit. Pat |
Sorry, double post |
Author: | Woodie G [ Sun Apr 10, 2016 7:29 am ] |
I like the plywood construction, Mr. True - looks as though it would be easily moved, as well as leave more space for the spinner nut and washer. You are giving me ideas for my own 'someday' shop! Thanks! |
Author: | jfmckenna [ Mon May 02, 2016 1:19 pm ] |
Well, thanks to OLF and this thread I have a very nice new addition to my new shop bench. |
Author: | gregorio [ Mon May 02, 2016 6:14 pm ] |
Since this thread popped back up i would like to ask a question. Do you find cabinetry (uppers / lowers) and countertop space most useful, or a large working bench area? I am building my shop in the basement and have a nice selection of reclaimed cabinets that I would like to use. Also, i have a large benchtop that i would like to utilize; shop will only provide for one or the other, not both. This project has been slow going, but all the harder boring work is done now. Getting into the subtle design and attractions now. The shop has to keep pace with the living space or ill get in trouble. o_0 Attachment: shop.jpg ty gregor |
Author: | jfmckenna [ Thu May 05, 2016 3:15 pm ] |
I personally don't care for cabinets because I don't like to have to open doors to see what's inside. I just like shelves and or cubby holes. Larger work benches could be nice but as long as it's long enough and wide enough to fit a guitar with a good amount of space around it AND even more importantly you can walk around it, so like a bench in the middle of the room. |
