It is currently Sat Aug 16, 2025 6:17 am
PostPosted: Fri Mar 18, 2016 2:35 pm
I bought it as a neck blank specifically just to see what commercial offerings might yield. It is second grade, but I really wouldn't have thought the off vertical grain would be at all passable as a sellable product. Too fussy?Image
PostPosted: Fri Mar 18, 2016 2:43 pm
Hardly fussy.
That's rift sawn, not even any grade far less second.
PostPosted: Fri Mar 18, 2016 4:52 pm
First name: Brad
Last Name: Combs
When I'm pilfering around in the sapele at the local wood store I use the chart on LMI's site as a reference to what is acceptable. Is that a good indicator? Because I read their note about 25 degrees and it makes me think this is on the low end of acceptable. Thoughts?
http://www.lmii.com/products/mostly-wood/neck-woods
PostPosted: Fri Mar 18, 2016 5:07 pm
Last Name: Kincheloe
This one's more like 60 degrees off...
I'm not sure it really matters though. I'm more picky about straightness of grain along the length of the neck (i.e. whether it's going to curve or twist when the humidity changes).
These users thanked the author DennisK for the post: bcombs510 (Fri Mar 18, 2016 5:33 pm)
PostPosted: Fri Mar 18, 2016 5:41 pm
It's more a marketability issue than structural.
PostPosted: Fri Mar 18, 2016 6:06 pm
First name: Ringo
I'd want to see the long grain before passing judgement. If the grain is straight all the way down the faces with no knots or defects I'd build with it no problem. There's about a bajillion flatsawn maple necks on Fenders that are doing just fine.
These users thanked the author James Ringelspaugh for the post: ChuckH (Sat Mar 19, 2016 4:22 pm)
PostPosted: Fri Mar 18, 2016 6:49 pm
Indeed.
PostPosted: Fri Mar 18, 2016 7:52 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
If the grain is straight along the length of the board, I would use it. Vertical grain on necks is about appearance, not strength or stability. I have used all manner of grain orientation on necks...from vertical to flat sawn.
PostPosted: Fri Mar 18, 2016 8:50 pm
I would use it, but then again I don't worry about marketability. Do clients worry about quartersawn necks in the handmade guitar market?
PostPosted: Fri Mar 18, 2016 10:13 pm
Some do some don't. Some people get their knowledge mostly from the Internet...
PostPosted: Sat Mar 19, 2016 6:37 pm
I have seen some people rip the board down the middle, flip one piece end for end and glue back together,
sometimes with a veneer or fillet of contrasting wood in the center. Grain will make a 'V' shape. It's supposed to
make it more stable. But in any event, it looks nice
Brent
PostPosted: Sat Mar 19, 2016 6:48 pm
How long is the board Ed? You could cut in half and laminate the wide edge together with some walnut and maple. You'd yield 2 necks from it too.
PostPosted: Sat Mar 19, 2016 9:56 pm
Brent, I'm a fan of that too, if we can find the wood.
PostPosted: Sat Mar 19, 2016 9:58 pm
Rod, it's 35"x3x7/8". Not sure what you're suggesting, I think it is too small for that...
PostPosted: Sun Mar 20, 2016 11:26 am
Last Name: Beaver
City: Lake Forest
Brent
That is how I do it. I think it makes for a stronger, more stable and better looking neck!!!
Joe Beaver
Maker of Sawdust
PostPosted: Sun Mar 20, 2016 12:08 pm
Ya, none of the dimensions work for what I'm thinking of.
