Getting oil out of raw wood? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=47394 |
Author: | dertien616 [ Sat Mar 05, 2016 12:05 am ] |
Post subject: | Getting oil out of raw wood? |
I was sharpening a scraper and had some lubricant oil on my fingers. I forgot and touched the guitar now the back has a few spots with oil in the wood. How should I go about removing it? |
Author: | John Arnold [ Sat Mar 05, 2016 12:35 am ] |
Post subject: | Re: Getting oil out of raw wood? |
Naphtha. |
Author: | kencierp [ Sat Mar 05, 2016 7:50 am ] |
I've found out about "K2R" many years ago when I built and flew gas powered model airplanes. Its a spray on product that dries and turn into a white power that you dust or vacuum off. In process of drying it absorbs the oil, kinda suck it out of the wood fibers rather than deluting the oil with a solvent and spreading it out over a larger area. http://www.truevalue.com/product/5-oz-S ... /44035.uts |
Author: | Clay S. [ Sat Mar 05, 2016 8:56 am ] |
Dish washing liquid. Then rinse with water. |
Author: | ChuckH [ Sat Mar 05, 2016 11:21 pm ] |
I like to use nose grease. Yeap, just rub the skin on top of your nose with you thumb and index finger and wipe on the scraper, or put on a plane sole and you'll notice a big difference. Sent from my iPad using Tapatalk |
Author: | Bryan Bear [ Mon Mar 07, 2016 3:48 pm ] |
I absentmindedly set an unfinished body on a surface treated with mineral oil. A few days later I went back down to the shop and found the stain. The oil was even showing through on the other side. The advice I got was to use naptha. It took about three liberal applications to remove all traces of the oil. No finish (shellac) issues either. |
Author: | Mark Fogleman [ Fri Mar 11, 2016 12:09 am ] |
If the Naptha doesn't work or you can't get it where you live you may want to try Corn Starch or finely ground kitty litter. Leave it on for a day or so and it will absorb the oil. +1 on the nose grease. It's what I've used for a long time. |
