Kerfed lining making gizmo
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=47375
Page 1 of 2
Author:  Michaeldc [ Mon Feb 29, 2016 2:24 pm ]
Post subject:  Kerfed lining making gizmo
Here is a video of an automated kerfed lining fixture I just batched up. It work for both regular and reverse linings.
https://youtu.be/6zXhLX6M9FI
Sorry about the noisy bearing... I've since put some oil on that thing.
Michael
Author:  Don Williams [ Mon Feb 29, 2016 2:31 pm ]
Post subject:  Re: Kerfed lining making gizmo
Nicely Done! Can you vary the spacing of the cuts?
Author:  meddlingfool [ Mon Feb 29, 2016 2:37 pm ]
Slick!
Author:  Michaeldc [ Mon Feb 29, 2016 2:42 pm ]
Thanks Don
Yes, I can vary the spacing and the cut depth.
Author:  Heath Blair [ Mon Feb 29, 2016 3:00 pm ]
That is one of the coolest dang things I've ever seen.
Author:  Colin North [ Mon Feb 29, 2016 3:17 pm ]
Nicely done Michael!
Author:  Alex Kleon [ Mon Feb 29, 2016 3:52 pm ]
Cool! Even makes it's own industrial soundtrack!
Alex
Author:  Pat Foster [ Mon Feb 29, 2016 6:10 pm ]
Too cool!
Author:  JSDenvir [ Mon Feb 29, 2016 6:17 pm ]
I just have to keep reminding myself that envy is a terrible thing. :-)
Very cool.
S
Author:  Mike OMelia [ Mon Feb 29, 2016 10:02 pm ]
That's pretty cool. You seen Keith Mackensie's version? Chris Paulick posted this a while back. Very similar designs.
http://youtu.be/h-pdUWoNjPo
Author:  Michaeldc [ Mon Feb 29, 2016 10:26 pm ]
Mike,
My inspiration is based on Keith's design. I probably watched the YouTube video 30 times, studying the motion of the fixture. I probably thought about it another 3-4 days before drawing it so I could so I could cut the parts on my cnc machine. It was a very fun problem!
Chris, the presenter of Keith's design it pretty toasted, if you hadn't noticed.....
Author:  Mike OMelia [ Mon Feb 29, 2016 10:38 pm ]
Chris always looks that way. You probably wouldn't want to see me in a video. ;)
Thank you for attributing design to Keith. I'm sure he'd be flattered to see your interpretation. It's good work.
Author:  Michaeldc [ Mon Feb 29, 2016 10:42 pm ]
I love watching him set his beer down on the base of the band saw after struggling to get through the introduction....
Author:  Mike OMelia [ Mon Feb 29, 2016 10:42 pm ]
I could never get Keith to provide the design. But, I'm sure you could sell the cut parts if reasonable. I'd entertain your quote.
Author:  Mike OMelia [ Mon Feb 29, 2016 10:43 pm ]
Lol. Well Chris does do good jig work. Learned a lot from him.
Author:  Michaeldc [ Mon Feb 29, 2016 10:48 pm ]
I'd have to see if the fixture would fit other 14" saws before offering up the design for sale.
Author:  Mike OMelia [ Tue Mar 01, 2016 12:16 am ]
It will.
Author:  kencierp [ Tue Mar 01, 2016 8:54 am ]
Our machine is a stand alone tool -- an inexpensive Delta 10" was converted. The basic plan for this device has been around for a long time and can be found at frets.com
Author:  jfmckenna [ Tue Mar 01, 2016 11:13 am ]
That's fantastic! I use kerfed linings sometimes and it's one of the only things I outsource because the time and frustration involved in doing it is simply not economically worth it. In fact I mostly do solid linings because it's a lot easier.
So if you produce any for sale let me know and I can at least help you pay off that cool jig!
Author:  doncaparker [ Tue Mar 01, 2016 11:29 am ]
Alex
I can just hear Raymond Scott's Powerhouse, the music of busy machines that we all know from the old Warner Brothers cartoons.
Author:  kencierp [ Tue Mar 01, 2016 12:11 pm ]
http://frets.com/FretsPages/Luthier/Too ... erfer.html
Author:  Michaeldc [ Tue Mar 01, 2016 12:31 pm ]
kencierp wrote:
http://frets.com/FretsPages/Luthier/Tools/LiningKerfer/liningkerfer.html
Went out and found it over tea this morning.
Author:  Pmaj7 [ Tue Mar 01, 2016 4:20 pm ]
Nice! It's sort of steampunk. You could somehow have the finished one trigger the next one in the chute and let'r run!
How thick is the web? is it flat or w shaped?
Author:  Michaeldc [ Tue Mar 01, 2016 4:42 pm ]
The web is about .020" thick though it's fully adjustable. The first batch I made (50 pieces) has got a round-over just like reverse kerfed linings only they are cut like standard linings. You can make reversed or regular simply by flipping the piece.
Author:  kencierp [ Tue Mar 01, 2016 5:31 pm ]
I set up the stroke mechanism on ours using a cam action. There's a spring loaded buffer bar to compensate for wear and also allow fine adjust using shims --- you can see my very high tech card stock and masking tape shim on the slide stop. I should really confess that this device was built several years ago as a concept model -- the principles involved and the design road map put forth by Frank Ford where so good that we just continue to use this in production.
