Wormhole fill before bend http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=47326 |
Author: | Mike OMelia [ Sun Feb 21, 2016 11:14 pm ] |
Post subject: | Wormhole fill before bend |
Trying something new. I had couple of wormholes in my sides. Before bending, I decided to epoxy with dust. Anybody done that before? |
Author: | Rod True [ Mon Feb 22, 2016 12:41 am ] |
Post subject: | Re: Wormhole fill before bend |
The epoxy will soften with heat. CA and dust would be better. |
Author: | Colin North [ Mon Feb 22, 2016 5:43 am ] |
I seem to remember a Robbie O'Brian video recommended using CA and wood dust https://www.youtube.com/watch?v=rqSglfu6xtA Not sure about epoxy, but from a quick search, it looks as if heat resistance depends on the epoxy. |
Author: | Nils [ Sat Feb 27, 2016 9:51 am ] |
why not fill after you bend? |
Author: | Pat Foster [ Sat Feb 27, 2016 10:25 am ] |
MIke, Take special care if there are any worm tunnels, especially if they run across the grain. They can cause a kink in the bend. |
Author: | Hesh [ Sat Feb 27, 2016 12:05 pm ] |
Mike I've filled worm holes with epoxy and dust prior to bending with no issues. The ep*xy that I used back then was the Pacer line, makers of Z-Poxy and it worked great. IIRC I used their 30 minute stuff. There used to be a toot on filling worm hole on Allied's site and that's what I learned from. |
Author: | Hesh [ Sat Feb 27, 2016 12:08 pm ] |
Just found it, still there at Allied. http://www.alliedlutherie.com/filling_a_hole.htm |
Author: | Mike OMelia [ Mon Feb 29, 2016 12:00 am ] |
It worked ok. Still have to do some touch up work. Won't try it again though. |
