It is currently Sun Aug 17, 2025 12:16 am
PostPosted: Tue Jan 19, 2016 10:19 pm
Here a little thing I cobbled together after a thing they had at Larrivee. Should have done it 15 years ago, but oh well.
Basically, it just holds a laminate trimmer keyed into the truss rod slot for indexing. It has a 3/8" ball nose bit. There is a little bit of wiggle in it intentionally, as the fat end is 3/8" exactly, so the wiggle room let you get a slightly wider than 3/8 pocket. Leaves a nice clean cut, though I expect this would be better served with a downshear spiral, but for now..,
Imagewith neck in place..Imagegadget
Imageindexed into the slot
Imagezing zing
Imageclean
Imagefits!
PostPosted: Wed Jan 20, 2016 12:44 am
That's nice.
PostPosted: Wed Jan 20, 2016 1:17 am
Thanks. Also turns two steps into one. I used to gouge the neck end out with chisels, and then route the body with a template and collar. This condenses it into one faster step, and it looks better, not that anyone sees there.
PostPosted: Wed Jan 20, 2016 1:45 am
Good stuff Ed!
PostPosted: Wed Jan 20, 2016 2:21 am
Monkey see, monkey do...;)
These users thanked the author meddlingfool for the post (total 2): Clinchriver (Wed Jan 20, 2016 7:18 am) • Rod True (Wed Jan 20, 2016 2:43 am)
