It is currently Sun Aug 17, 2025 9:39 pm
 Post subject: Source for go bars?
PostPosted: Tue Dec 08, 2015 6:03 pm
I'm looking for the rectangular type fibreglass ones that are sort of yellow.
I am forever done with the rinky dink accursed round kite rods.
I would prefer not to resort to stewmac. Anybody know of a place that would sell them, or what they are called when they're not called go bars?
 Post subject: Re: Source for go bars?
PostPosted: Tue Dec 08, 2015 8:01 pm
Hi Ed,
I saved myself the trouble of searching or paying too much for fiberglass rods and made a bunch out of Oak, Cherry and Alder. Just use good straight grained stock with minimal run out. Mine were leftovers from cabinet jobs. The Alder is a bit too soft, so don't use that. Maple would be good.
Used the band saw to rip 4/4 stock to 3'8"x 1/2", my deck is 50" tall, so you might have to make the pieces smaller if your deck is shorter. I sand the corners off and smooth the business end, but leave the corners on the top too help grip the top of the deck.
These users thanked the author StevenWheeler for the post: jack (Tue Dec 08, 2015 8:21 pm)
PostPosted: Tue Dec 08, 2015 8:43 pm
How consistent are they from bar to bar? How long do they last before taking such a set as to make them unuseable?
PostPosted: Tue Dec 08, 2015 9:05 pm
I'm sure Ed want's the consistency that a fibreglass bar would add.
Ed, check out http://www.tapplastics.com/product/plas ... ar_bar/160 There's one down in Washington north of Seattle. Can't seem to find any Canadian suppliers though.
PostPosted: Tue Dec 08, 2015 9:07 pm
I don't have the use requirement as you do Ed but I just took some 3/4" maple hardwood (my neighbour was tossing out his extra after putting in new flooring) and cut them to 1/4" on the table saw and cut them to length. That was 10 years ago and I've not broken one. If it's bending slight in one way I'll just place it so it bends the other way. Even with a rounded bottom then dent my brace stock after clamping.
PostPosted: Tue Dec 08, 2015 9:11 pm
Or I'd phone one of the local plastics places (Industrial Plastics or Plastics works, google) to see if they might now of a local source.
PostPosted: Tue Dec 08, 2015 9:26 pm
Thanks Rod,
The price on that makes stewmac look like that's not such a bad deal after all. I'd like to avoid the 'luthier' upcharge, but we'll see. I'm not too concerned with them taking a set, as long as they still give enough pressure.
Maybe I'll cut some plywood...
PostPosted: Tue Dec 08, 2015 9:38 pm
I think my batch is about 8 years old but like Rod I do a few guitars a year not a week like you. The Oak and Cherry are pretty consistent in strength (no empirical data) the Alder is quite a bit weaker. None have taken a set that lasts long after being unsprung. The good ones won't take set unless left under tension over night, they straighten back out in an hour. Also like Rod, I'll bend them opposite of how they want to go when loading in the deck.
I vote no to the plywood.
PostPosted: Tue Dec 08, 2015 9:44 pm
Yes, that as a swiftly failed experiment:)
PostPosted: Tue Dec 08, 2015 11:04 pm
Last Name: Farmer
City: Durango
State: CO
+ 1 for wood!
Straight grain is all you need. Just run them through your thickness sander until you have the spring you want. round rods are a nightmare swinging all around. I have Pine, Oak, Redwood, etc. Cabinet shops produce miles of rips too thin for them to use.
A roundover bit on a router table makes them comfy. tapered ends gives room for cleaning squeezout.
I never understood the low head banger decks w/ supports in the way and finicky positioning. I run them to the ceiling. Long light bars to the ceiling can be positioned anywhere on the top w/ out moving the top anchor point and accommodate a wide range of thicknesses.
What's not to like?
These users thanked the author david farmer for the post: Robbie_McD (Wed Dec 09, 2015 8:46 am)
PostPosted: Tue Dec 08, 2015 11:40 pm
What us that big black thing in the corner?
PostPosted: Wed Dec 09, 2015 12:32 am
Last Name: Farmer
City: Durango
State: CO
LOL. I forget how strange that thing looks. Insulated tank for solar hot water.
PostPosted: Wed Dec 09, 2015 1:05 am
Dave, I too like a lot of head room when working around the braces
But yours are a bit of a storage issue no?
PostPosted: Wed Dec 09, 2015 1:28 am
Last Name: Farmer
City: Durango
State: CO
They do have to be stored vertically. I just lean them in a corner, but your right, if you don't have the room to swing them around they could be annoying.
PostPosted: Wed Dec 09, 2015 10:09 am
First name: Bobby
Last Name: Masten
City: The Woodlands
Zip/Postal Code: 77380
If you decide on the fiberglass ones instead of cutting your own, this supplier offers them for about 1/3 the cost of Stewmac.
http://ultimate-guitar-online.ultimate- ... c69efdd4a1
Bobby Masten
PostPosted: Wed Dec 09, 2015 10:19 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
driveway markers from Lowes 1/4in fiberglass in red/ yellow . I purchased rubber bottoms from a supplier in seattle
PostPosted: Wed Dec 09, 2015 11:05 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I bought driveway markers from Dollarama for $1 each. About 5/16" x 48" with a plastic tip on one end, sharpened on the other. I cut them down, keeping the sharp end to bite into the carpet that I put in the underside of the go deck top.
Alex
PostPosted: Wed Dec 09, 2015 12:31 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I too use the ceiling for my gobar deck and love being able to just lean the bars against the wall when not in use. Unlike David though, mine is against the wall so I don't have easy access for glue cleanup from all directions. I'd love to figure out a way to have it in the middle of the room like that.
Bryan Bear PMoMC
PostPosted: Wed Dec 09, 2015 12:51 pm
Are they round, Alex?
I am dead set against round go bars...
PostPosted: Wed Dec 09, 2015 3:49 pm
First name: Alex
Last Name: Kleon
City: Whitby
Yes the are, Ed. I guess it would be easier to control the direction of the bend with square. Even with my very limited experience, I can understand your dislike for the round rods. I'd be interested in finding square fibreglass as well.
Alex
PostPosted: Wed Dec 09, 2015 4:14 pm
Last Name: Lloyd
I've used the kite bars from https://goodwinds.com/.
You can cut the 4' x (3/8") in half. Don't forget to order the plastic ends.
Michael Lloyd
PostPosted: Wed Dec 09, 2015 4:30 pm
PostPosted: Wed Dec 09, 2015 5:41 pm
Use spring tension curtain rods. Easy to adjust the tension, no sideways force since they can be put in straight up and down with no bend and easy to adjust the length for different situations. Plus they come with nice rubber knobs on their ends.
PostPosted: Wed Dec 09, 2015 6:04 pm
How much pressure do they give, Pat?
PostPosted: Wed Dec 09, 2015 6:17 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I currently use round fiberglass rods, but I definitely see the virtue of moving to rectangular bars. The round fiberglass rods tend to have a mind of their own for a moment or two after you place them, in terms of where the bent part will go. This, of course, can affect the business end of the rod. Placement takes more attention than I want to give it. I might have to move to wood slats.
