Laminated neck blocks? http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=46767 |
Author: | meddlingfool [ Wed Dec 02, 2015 1:50 pm ] |
Post subject: | Laminated neck blocks? |
I've had to resort to making 2pc laminated necks. There an awful lot of waste wood, which looks large enough for laminated neck blocks. I can't see an issue with it, especially as I use a bolt on butt joint. Any thoughts? ![]() |
Author: | Glen H [ Wed Dec 02, 2015 1:54 pm ] |
Post subject: | Re: Laminated neck blocks? |
I have used neck blocks made from more than one piece. I just keep the seam perpendicular to the body length so it's always under compression (also compressed by my bolts). Don't know if it's the 'right way' but I've done it and haven't had a problem yet. |
Author: | Hesh [ Wed Dec 02, 2015 2:02 pm ] |
Should not be an issue with a bolt-on. For dovetails I would not use laminated blocks because come reset time, and it will.... the steam may delaminate the neck block. |
Author: | DannyV [ Wed Dec 02, 2015 2:21 pm ] |
Glen H wrote: I have used neck blocks made from more than one piece. I just keep the seam perpendicular to the body length so it's always under compression (also compressed by my bolts). Don't know if it's the 'right way' but I've done it and haven't had a problem yet. ![]() |
Author: | jfmckenna [ Wed Dec 02, 2015 4:15 pm ] |
I use the same type joint and mine are all 3 or even 4 piece. Blocks, linings and the like are good areas to use pieces of wood that fall on the shop floor ![]() +1 on the dovetail though. |
Author: | meddlingfool [ Wed Dec 02, 2015 4:42 pm ] |
Dovetails are a relic of my past, no fear there... |
Author: | Tai Fu [ Thu Dec 03, 2015 12:11 am ] |
I made laminated neck blocks... I laminated it with epoxy thinking that when reset time comes, epoxy won't come apart at all. |
Author: | Tom West [ Thu Dec 03, 2015 9:22 am ] |
Ed: I've used stacked neck blocks and never had a bit of problem and I think laminated should be OK. As long as one keeps the grain parallel to sides I don't see a problem. A bit of a note for Tai Fu.................While some epoxies may be impervious to heat, the kinds I have used can be parted with heat. Tom |
Author: | Barry Daniels [ Thu Dec 03, 2015 9:32 am ] |
You may not care about this, but I don't think a two piece (or even a 5 piece neck) should be called "laminated". Laminations are thin layers like you see in plywood. I use laminated heel and neck blocks made from baltic birch plywood. I think there are definite advantages to this approach regarding stability, lightness, and crack resistance. |
Author: | ernie [ Thu Dec 03, 2015 10:00 am ] |
Trev recommends Epoxy for laminated neck blanks.For his bolt on bolt of necks |
