It is currently Sun Aug 17, 2025 4:41 am
PostPosted: Tue Nov 24, 2015 4:45 pm
First name: Brad
Last Name: Combs
Hello,
I have an opportunity to get a fair amount (probably ~100 board feet) of Honduran Mahogany. Not all of it is quartersawn. It's all about 9 inches wide and 3-4 inches thick. The boards are about 15 foot long.
If not on the quarter, what can I use this for? Can I use it for neck blanks? How about bracing? I'm guessing non-quarter B&S would be a bad idea?
Thanks for any ideas.
Brad
PostPosted: Tue Nov 24, 2015 5:20 pm
Last Name: Kincheloe
Straightness of grain is more important than quarteredness for necks. And Honduran mahogany in particular has less difference between the radial and tangential expansion rates than most woods (2.9% and 4.3%), so it should be especially fine. And 4.3% is still pretty low, so I wouldn't worry about using it for backs and sides either.
Quartersawn black walnut is worse than flatsawn Honduran mahogany, at 5.5% radial expansion. And quartersawn ebony is 8.3% :P
These users thanked the author DennisK for the post: bcombs510 (Tue Nov 24, 2015 8:07 pm)
PostPosted: Tue Nov 24, 2015 8:12 pm
First name: Brad
Last Name: Combs
Thanks, Dennis!
In an effort to learn to fish, if you have some links for research, recommended books, etc... I can read that would be great. :) I'm learning instrument building and woodworking at the same time, so double whammy. :)
I read the article here which seemed to explain some of what you describe above: http://www.woodworkerssource.com/shop/wmov.html
I'll pick up some of this wood and give it a shot. Might be time for a resaw king blade though. This will be some serious work.
Thanks!
Brad
PostPosted: Wed Nov 25, 2015 11:55 am
There is a lot of potential for a piece of wood like that in any shape or form. If it is a true flat sawn piece then that means that it is vertical grained on the 3-4in width side. 3-4in is big enough for sides and 4 piece backs. BUt even if the grain is off quarter you could use that for many many other things.
These users thanked the author jfmckenna for the post: bcombs510 (Wed Nov 25, 2015 5:24 pm)
Users browsing this forum: Bing [Bot] and 8 guests
