It is currently Mon Aug 18, 2025 12:18 am
PostPosted: Sun Nov 08, 2015 4:34 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I have a few rosewood bridge blanks like this one. I like the wavy grain pattern but I'm wondering if the curl would mean a weak glue joint with the top. It's over 8 inches long so if I used it, I could use the left end where the curl is less pronounced. [:Y:] or pfft ?
PostPosted: Sun Nov 08, 2015 4:53 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I think that you should send me a couple of those bridge blanks for some in depth analysis, Jay. ;)
Alex
PostPosted: Sun Nov 08, 2015 4:57 pm
Last Name: Kincheloe
Probably a bit weaker, but you could make it a bit bigger to compensate. Also, you could warm up the bridge and then pre-coat it with thin hide glue, let it dry, give it another light sanding on the guitar to remove any raised grain, and then do the final glue-up. That should clog any exposed endgrain, and give a better mating surface.
I think it would look great on a curly redwood top :) But then your joint is even weaker... but I remember a thread on the AGF where Harvey Leach posted a picture of a curly redwood 12 string with a typical sized bridge, and said it's been fine for over 10 years. So that pretty much confirms that curly joints aren't doomed to fail.
And if you do use curly redwood, do the hide glue pre-coat on that too. As mentioned in this thread, the exposed endgrain of curly redwood can suck up a lot of finish, and therefore would likely do the same to glue.
These users thanked the author DennisK for the post: J De Rocher (Sun Nov 08, 2015 5:46 pm)
PostPosted: Sun Nov 08, 2015 5:26 pm
Last Name: Sollod
I love that bridge blank! It looks kinda thin... Is it 3/8"?
www.swiftcreekguitars.com
PostPosted: Sun Nov 08, 2015 5:44 pm
First name: Danny
Last Name: Vincent
IMHO no it would not.
PostPosted: Sun Nov 08, 2015 5:49 pm
First name: Jay
City: Bothell
State: Washington
Thanks for the replies.
Alex - Thanks for the offer, but I'm already fully committed to a full in depth analysis with replication here.
Steve - It's about 7/16ths thick so it'll work.
PostPosted: Sun Nov 08, 2015 6:29 pm
First name: Alex
Last Name: Kleon
City: Whitby
I thought so! I'm looking forward to seing it on one of your guitars!
Alex
PostPosted: Sun Nov 08, 2015 8:39 pm
First name: Ringo
Will likely be just fine, in fact I wonder if the reversing grain might make it less prone to crack under the forces resulting from string tension.
PostPosted: Sun Nov 08, 2015 9:08 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
That is one sweet piece of wood!
PostPosted: Mon Nov 09, 2015 10:53 pm
I like that piece. I don't know if this is a good idea for a bridge but what about stabilizing it with shellac? Like one would do with a knife handle or pen blank... You'd need to hold the piece in the shellac under vacuum for 24 hours or better.
PostPosted: Tue Nov 10, 2015 12:39 am
First name: Jay
City: Bothell
State: Washington
I'm not sure what you mean by reversing the grain.
PostPosted: Tue Nov 10, 2015 12:40 am
First name: Jay
City: Bothell
State: Washington
Would the shellac treatment improve the strength of the glue joint?
PostPosted: Fri Nov 13, 2015 12:49 pm
I don't know.
What the shellac does though is fuse the wood together internally this strengthening the wood fibres. Don't think it would effect the gluability though.
These users thanked the author Rod True for the post: J De Rocher (Fri Nov 13, 2015 12:59 pm)
PostPosted: Fri Nov 13, 2015 2:09 pm
Given the vast holding strength of glue vs the relatively light load, I'd wager that as long as you got a good bridge fit, it'll be just fine.
These users thanked the author meddlingfool for the post: J De Rocher (Fri Nov 13, 2015 4:08 pm)
