Saddlematic mystery
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=46638
Page 1 of 2
Author:  Mike OMelia [ Mon Nov 09, 2015 11:35 pm ]
Post subject:  Saddlematic mystery
I was going through my guitar tool drawer and came across this (picture below). All was sealed in a plastic bag including the instruction sheet. Now, I know what a saddlematic is. And none of this appears in the manual. What is this tool set?
Author:  meddlingfool [ Mon Nov 09, 2015 11:43 pm ]
Post subject:  Re: Saddlematic mystery
Methinks you've used the old bag to put some random stuff in...
Author:  Mike OMelia [ Tue Nov 10, 2015 12:11 am ]
Nope. It was sealed until tonight.
Author:  J De Rocher [ Tue Nov 10, 2015 12:13 am ]
Looks like the bridge pin hole chamfering tool.
http://www.stewmac.com/Luthier_Tools/Types_of_Tools/Reamers/Bridge_Pin_Hole_Chamfer_Tool.html
Author:  Rod True [ Tue Nov 10, 2015 12:25 am ]
That looks like a plug cutter and drill stop....
Author:  SteveSmith [ Tue Nov 10, 2015 5:01 am ]
J De Rocher wrote:
Yep.
Author:  Colin North [ Tue Nov 10, 2015 5:21 am ]
Wrong instruction sheet
Right one
http://www.stewmac.com/How-To/Online_Resources/Bridges_and_Tailpieces/Bridge_Pin_Hole_Chamfer_Tool_Instructions.html
Author:  GustavBuhund [ Tue Nov 10, 2015 9:01 am ]
Bridge hole chamfering tool, definitely
Author:  Quine [ Tue Nov 10, 2015 11:35 am ]
Clear sign of Tool Acquisition Syndrome
Author:  SteveSmith [ Tue Nov 10, 2015 3:09 pm ]
I have that little tool and it works very well for me.
Author:  J De Rocher [ Tue Nov 10, 2015 4:32 pm ]
Me too. I used mine the other day on a rosewood bridge. The pilot keeps the tool centered on the hole and it cuts cleanly. I use my grandpa's very old hand cranked hand drill which gives good control.
Author:  RustySP [ Tue Nov 10, 2015 4:53 pm ]
Now I understand why I cant locate the saddle with that tool.
Neither will the saddlematic chamfer holes!
Mike, are you buying tools and just throwing them in a drawer without even trying them out?
You do have TAS.
Author:  Herr Dalbergia [ Tue Nov 10, 2015 5:02 pm ]
smile
had a shitty day toady, thanx for making me laugh
cheers, alex
Author:  dzsmith [ Tue Nov 10, 2015 7:14 pm ]
Looks like what was left over when I assembled a ride-on toy last xmas.
Author:  Mike OMelia [ Tue Nov 10, 2015 7:36 pm ]
This is indeed a symptom of TAS. I don't have it as bad as I used too. Back in the day, I was a sorry case. Thanks for the ID. Maybe I will try it out for the intended purpose. I have 5 bridges waiting for chamfers.
Author:  johnparchem [ Tue Nov 10, 2015 7:54 pm ]
I really like the tool.
Author:  Mike OMelia [ Tue Nov 10, 2015 9:29 pm ]
Can I use it on a drill press? I don't have any directions.
Oops. I see someone posted instructions above. But, experiences are welcome
Author:  Colin North [ Wed Nov 11, 2015 4:18 am ]
I'm getting clean chamfers effortlessly with a small cordless drill.
Depth stop may polish the top of the bridge but does not damage it.
Rather than setting the depth stop just with the grub screw as per instructions, I fitted some 10 x 16 x 0.3 mm shim washers behind brass/plastic stop against shoulder of cutter to give consistent diameters at top of chamfer (I use 2 or 3)
Useful if you disassemble to clean the tool as it goes back to exactly the same setting and there's no chance of the grub screw slipping during use.
Author:  SteveSmith [ Wed Nov 11, 2015 4:47 am ]
yep - feed easy
Author:  Mike OMelia [ Sat Nov 14, 2015 3:21 pm ]
I really like this tool. Very nice chamfers.
Author:  J De Rocher [ Sat Nov 14, 2015 3:28 pm ]
Maybe it would be worth digging through your tool drawer again to see what else turns up. [:Y:]
Author:  Mike OMelia [ Sat Nov 14, 2015 5:09 pm ]
I think you are right. After these builds I'm having a shop clean out and reorg. There was a time when all I did was hang out in the classifieds here and in other sites. You wouldn't believe the stuff I bought over at sawmill creek. I don't know what that chamfer tool costs, but I recommend it. Way better than the typical chamfer tool u can get at big box.
Author:  Mike OMelia [ Sat Nov 14, 2015 5:12 pm ]
I do have a question about that stepped drill bit for tuner installs. Will it work for Gotohs? Are there industry standards for tuner posts? I'm tired of the setup require to swap out bits and set depths
Author:  johnparchem [ Sat Nov 14, 2015 7:01 pm ]
I have a couple of those, I found you have to look at the spec for the tuner. They make a few different ones.
I found another sure fire way with normal bits. Drill a small pilot hole all the way through. On the top drill with the right size bit for the bezel the correct depth, then change to the shaft bit and drill through. The pilot hole keeps things centered.
Author:  J De Rocher [ Sat Nov 14, 2015 7:59 pm ]
I just finished installing a set of Gotoh M6 style tuners a few minutes ago. This was the first time for me making the tuner holes using a brad point bit to drill a pilot hole followed by StewMac's rear peghole reamer which leaves a step down in diameter for the tuner post (I used the drill press for both). I don't know if these tuners or the tool are the same as you have in mind, but the reamer worked as advertised.
http://www.stewmac.com/Luthier_Tools/Tools_by_Job/Tuner_Installation/Rear_Peghole_Reamer.html
