It is currently Sat Aug 16, 2025 6:25 pm
 Post subject: Can you un-bend a side?
PostPosted: Tue Oct 27, 2015 2:24 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Zip/Postal Code: 30308
If I bent.... I mean.... If a friend of mine bent 2 two left sides, could the one be straightened out and then re-bent the other direction? It was taken out of the bending machine after bending but before being "cooked" for too long. It was only in there about 15 minutes.
It's EI RW, by the way. It's a dreadnought.
My friend is an idiot.
"I'm not going to say that perfection has never been achieved. However, if it has, it probably went unnoticed due to it's lack of character."
PostPosted: Tue Oct 27, 2015 2:28 pm
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
Not that I have ever done this.... But I have used my Wife's iron - I mean an advanced Unbending iron device - to unbend a side. Worked great.
Glenn
These users thanked the author Glenn LaSalle for the post (total 2): JSDenvir (Tue Oct 27, 2015 4:58 pm) • Michaeldc (Tue Oct 27, 2015 4:02 pm)
PostPosted: Tue Oct 27, 2015 2:44 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Glenn
Did you then bend it in the opposite direction?
PostPosted: Tue Oct 27, 2015 2:46 pm
I think someone on this forum once showed us a link with a kind of big iron used in hotels, there was enough room to put a side in it and flatten it.
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
I'm also wondering how long I should wait to try to rebend it. I know that wood will tend to case-harden after being bent. Just don't know how long it takes to rehydrate again. It's raining here if that makes any difference.
PostPosted: Tue Oct 27, 2015 2:48 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Glenn
I second this except for "wife's iron" You can get a cheap one at a true value or any big box hardware store for around $14.
PostPosted: Tue Oct 27, 2015 2:53 pm
I've straightened and re-bent EIR, Walnut and Maple -- not sure I buy the case hardened premise not been a problem for us? But anyway, we mostly discover the error right away -- spritz it and go to work to correct the error.
Ken Cierp
PostPosted: Tue Oct 27, 2015 3:10 pm
I've rebent sides the opposite way before. EIR is about as forgiving as it gets. If you have a bending pipe, "unbend" it on the pipe then put it back in the bending machine. If you don't have a pipe, put it back in the slats and blanket and get it hot and work it along the edge of your bench to straighten it, then put it back in the machine.
Don't forget to bend it the correct way the 2nd time around.
PostPosted: Tue Oct 27, 2015 3:30 pm
Last Name: Shanklin
City: Windsor
State: ON
A cheap steam iron is the best tool I have found for unbending.
Bob
PostPosted: Tue Oct 27, 2015 3:40 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Thank you so much for all the replies. I have a steam iron but I think my heating blanket should do the trick. At least for initially straightening it out. If there are any bubbles or faceting still going on, I bet the steam iron would work great.
PostPosted: Tue Oct 27, 2015 3:41 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Roger that!
These users thanked the author absrec for the post: Michaeldc (Tue Oct 27, 2015 4:04 pm)
PostPosted: Tue Oct 27, 2015 6:07 pm
First name: Rusty
Yes a clothes iron and a damp rag. Just heat the high spots and when the wood starts to relax iron the whole side flat.
PostPosted: Tue Oct 27, 2015 8:05 pm
First name: Howard
Last Name: Wilson
I've found that spritzing SuperSoft II will almost immediately take bends out without any heat applied. DAMHIKT.
PostPosted: Tue Oct 27, 2015 8:29 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Glenn
Now wait a second! Why wouldn't he bend it in the opposite direction? Lol.
Yes, I've done this before. And the clothes iron worked.
PostPosted: Tue Oct 27, 2015 8:39 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Thank you Henry W. Seeley! I managed to get this thing flattened out with an iron. I have it clamped to my bench under a board. I'll try re-bending it (In the correct orientation this time) sometime tomorrow.
Thanks again for the tips everyone.
PostPosted: Wed Oct 28, 2015 5:34 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Just re-bent that side. Couldn't have gone smoother.
PostPosted: Wed Dec 30, 2015 2:10 pm
Just looked this back up to see how it turned out (cause I have to re-bend a side too).
Aaron can you show us some more pictures of your vise there.....? Looks like some custom mods from a typical pattern makers vise.
PostPosted: Wed Dec 30, 2015 2:45 pm
Let us see how yours turns out, Rod. I may need it any day! [:Y:]
PostPosted: Thu Dec 31, 2015 12:19 am
Last Name: Hammond
Lets see a show of hands, how many people have bent two left sides?
Oh my goodness!!
What a bunch 'a' knuckleheads--- gaah
The Biggest Little City, Nevada
www.hammondguitars.com
I love building guitars!
PostPosted: Thu Dec 31, 2015 12:23 pm
I once bent a side for an OM. Not only was it bent for the wrong side, but I decided to make a cut-away body instead of regular. So I had to unbend the side, and, not only just rebend it the opposite way, but needed to bend in the cut-away shape, too.....and it was Snakewood, one of the more difficult woods to bend. I soaked it in hot water for about a half hour and was then able to get most of the original bend out with a clothes iron, enough to get the heating blanket and slats on. It rebent easily into the opposite side with the cutaway. That's my worst side bending horror story, and it ended happily :D
Grant
PostPosted: Thu Dec 31, 2015 12:34 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
You can do anything that you put your mind to. [:Y:]
Happy New Year!!!
PostPosted: Thu Dec 31, 2015 4:01 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
It's a good thing the stuff grows on trees! :)
Alex
PostPosted: Thu Dec 31, 2015 4:04 pm
Hmmm, I hope you corrected that mistake with the linings too ;)
PostPosted: Thu Dec 31, 2015 8:33 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
It depends on the wood.
For oily woods like EIR you could practically bend it backwards and forwards, all without heat. I bent them backwards and forwards a few times to correct a few mistakes.
For woods that requires super soft II to even bend into a Dreadnaught shape, not so much...
Typhoon Guitars
PostPosted: Fri Jan 01, 2016 12:39 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I did it once early in my career. There is a simple way to avoid it. When I lay out the pattern to profile the sides, I draw a line on the inside of both sides at the waist. This is foolproof if you lay the sides together opened like a book, and mark both at once. I hand bend using a hot pipe, and the line shows me where to start the bend for the waist, and which direction to bend it (line facing up).
I have rebent many sides to change body shape. I have been known to soak sides in the bathtub for several hours. In my experience, wood that has already been bent once is actually a little easier to bend the second time around.
