Spraying order? Back/sides/top?
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=46228
Author:  Colin North [ Mon Aug 24, 2015 1:22 pm ]
Post subject:  Spraying order? Back/sides/top?
What order do you do them in, and why?
Author:  Mike Collins [ Mon Aug 24, 2015 1:34 pm ]
Post subject:  Re: Spraying order? Back/sides/top?
I do the back first.
because if there is something wrong with the air pressure-mixture-etc.
Author:  Mike Collins [ Mon Aug 24, 2015 1:38 pm ]
it's easier to fix on the back(for me)
Then sides,top last .
I akways take more time on it so it's easier to rub out & so a
mistake is not seen or hard to fix.
Then a single malt!!!!!
Author:  Josh H [ Mon Aug 24, 2015 5:28 pm ]
Sides-back-top. That way I'm not getting overspray from the sides onto the top and back.
But I imagine you can use pretty much any order and get good results.
Author:  Clay S. [ Mon Aug 24, 2015 5:45 pm ]
I spray the body flat. I tape off the fingerboard extension area and the bridge area and then tape a block on those areas to hold the guitar off the turn table. I first spray the top (heavy) and the sides (more lightly) and wait a few minutes for it to flash off. I then flip it onto the blocks and spray the back (heavy) and the sides again (more lightly). I then wait long enough for it to be dry enough to be placed on its back again before spraying a second coat.
Author:  kencierp [ Mon Aug 24, 2015 5:48 pm ]
I spray the sides then the sound board or back. I believe my fixture is a lot different than most. I spray in the horizontal position (like table top) the fixture has a 360 degree locking, rotating work holding detail. I found that the flat spray plane eliminates sag and allows the coating to flow out a little better My fan is down draft so it sucks everything toward the floor away from the work right from the get go.
Author:  DannyV [ Tue Aug 25, 2015 1:20 pm ]
What Josh said.
Author:  SteveSmith [ Tue Aug 25, 2015 6:33 pm ]
I use a StewMac Freehand Holder which lets me rotate the body. I spray sides, back, top.
http://www.stewmac.com/Luthier_Tools/Tools_by_Job/Finishing/Spraying/Freehand_Holder.html
Author:  Wayne Brown [ Tue Aug 25, 2015 6:40 pm ]
+1 for Josh H
Author:  Tom West [ Tue Aug 25, 2015 7:58 pm ]
Back, sides,and then top. Why? That's the way I did the first one..................!
Author:  Nils [ Sat Aug 29, 2015 9:31 pm ]
Its more about how the light happens to be hitting the instrument as I'm holding it. Whatever part I can see best I spray first typically. I usually start with the top or back I find though.
