Choice of Laminate Trimmer w/ Plunge Base...
http://mowrystrings.luthiersforum.com/forum/viewtopic.php?f=10101&t=46073
Author:  sdsollod [ Thu Jul 23, 2015 8:49 am ]
Post subject:  Choice of Laminate Trimmer w/ Plunge Base...
My wonderful wife gave me a $150 gift certificate to Woodcraft. They are having a sale this weekend and I thought I could maximize the gift. I could use another laminate trimmer. I thought maybe I should get one with a plunge base. Here are three models. Any recommendations? Help me out guys/ or gals…
Bosch
http://www.woodcraft.com/category/PT116 ... rand=Bosch
DeWalt
http://www.woodcraft.com/Product/848065 ... 611PK.aspx
Porter-Cable
http://www.woodcraft.com/Product/847926 ... e-Kit.aspx
Author:  kencierp [ Thu Jul 23, 2015 11:37 am ]
Post subject:  Re: Choice of Laminate Trimmer w/ Plunge Base...
Not much help -- but I think the Rigid has them all beat, I think in comparison, all their adjustment devices are clumsy to use -- $.02
Author:  dzsmith [ Thu Jul 23, 2015 12:17 pm ]
Bosch depth adjustment is terrible, but the variable speed option is great to have.
Don't know about the others.
Author:  mkellyvrod [ Thu Jul 23, 2015 4:44 pm ]
The Bosch is what I have, and like Dan, I'm not excited about the depth adjustment. Just by 2 cents.
Author:  Bri [ Thu Jul 23, 2015 6:34 pm ]
I have each of those, actually 3 of the PC. 3 because whenI bought the first it was really the only choice.
I hate to say this, because Normally I find Dewalt tools to be inferior, but that is my choice from your list.
All that being said I would likely buy the Festool should I ever need to add to my router collection.
( sorry Dewalt).
Author:  Aaron O [ Thu Jul 23, 2015 10:59 pm ]
DeWalt and PC are basically the same. I got the DeWalt.
Then, I got another one just to use the non-plunge base for headstock binding.
Want to get another one to replace my Laminate Trimmer in my binding jig.
Author:  Colin North [ Fri Jul 24, 2015 6:49 am ]
Just in case you hadn't thought about it there is also the Makita with adjustable speed, and although I'm not wild about the depth adjustment on the fixed base, the plunge base does have fine adjustment http://www.amazon.com/Makita-RT0701CX7-1-1-Compact-Router/dp/B00HAQMHEO/ref=sr_1_fkmr0_2?s=hi&ie=UTF8&qid=1437738055&sr=1-2-fkmr0&keywords=Makita+RT07+plunge+base&pebp=1437738062520&perid=16Z5D7HG8MBV7EZ3XVDT
I have one on my Wells-Karol, and just set the depth by shimming under the base for rosette work.
But I must admit, if I could have sourced the Rigid in this country it would have been my first choice, but I don't think you can get a plunge base for it.
Author:  rlrhett [ Fri Jul 24, 2015 7:30 pm ]
+1 on the Rigid. Can't believe I'm saying that, but a friend has two and I'm finding myself waiting to use his for binding channels and what-nots. Rigid is usually OK, not great. Not sure how they did so well on this trimmer. Smooth, powerful, well balanced, with good depth adjustment. Who knew?
Author:  Dave Fifield [ Sat Jul 25, 2015 4:18 am ]
If I were you, I'd save up some more then buy the Micro Fence Plunge Base and a PC or Bosch router that fits it.
Cheers,
Dave F.
Author:  Hesh [ Sat Jul 25, 2015 7:15 am ]
For the Collins Saddle Mill that we produce and sell we did an extensive evaluation of many of the laminate trimmers out there.
Unfortunately we had been spoiled by the best-in-class PC-310 that is no longer in production so our expectations were pretty high.
The Rigid from data that we received from a reliable Luthier who had purchased several of them, checked the run out and then took them all back was that the Rigid is the most sloppy choice with the most runout.
For one reason or another the Dewalt was the winner and what we now include with our Collins Saddle mill. We also modify the router with an expensive, aftermarket collet that dials it in even further.
I've yet to find a plunge base that is worth a crap though but we don't use the bases that come with the routers anyway because the entire Collins Saddle Mill is a plunge base in and of itself for the intended purpose.
The Dewalt also has a soft-start and is pretty quiet as well. No complaints.
Author:  Imbler [ Sat Jul 25, 2015 8:27 am ]
I went through the exercise of evaluating routers for my cnc, and the nod went to the dewalt. With a precisebits collet, the TIR runout was under a thousandth if my memory serves. Anyway it was a third of what the several Bosch's I had measured. Quiet, smooth, and precise,
Author:  WaddyThomson [ Sat Jul 25, 2015 10:02 pm ]
I bought one of the DeWalt trim router kits with both bases when I bought my headstock jig from Luthiertool.com. The plunge base has lots of options and adjustments, with good stops, and I like it very much for what I'm using it for. It's the only plunge base I have, so I can't really compare.
Author:  James Orr [ Sat Jul 25, 2015 11:25 pm ]
I prefer hand tools here.
In this case, I use my pinky nail and really dig into whatever I'm carving with a bit of a curved angle of attack, followed by a scoop. The technique works best on softwoods, but either way, I don't have to worry about runout or the danger of a bit coming loose.
My advice is to that the $150 and invest in some acrylic nails.
Author:  Terence Kennedy [ Sat Jul 25, 2015 11:45 pm ]
Consider getting a Bosch Colt or a used PC 310 and the Bishop Cochran base. It's the Cadillac.
http://www.bishopcochran.com
Author:  James Orr [ Sun Jul 26, 2015 11:09 am ]
Pinkies aside, this is my setup, too.
Author:  giltzow [ Sun Jul 26, 2015 11:53 am ]
+ 1 on the Dewalt
Author:  David J Fisher [ Sun Jul 26, 2015 12:44 pm ]
I vote for the Dewalt 611 pk. About six months ago I decided to buy a trim router. As far as I can tell, the dewalt and the porter cable are identical. The only difference I noted is that the Dewalt has the led's on the underside and the PC does not.
I really like the router, great plunge base. Good depth adjustments. I looked at Bosch and wasn't impressed. I have 2 of their 1617's but for trim routers, at the moment, Dewalt is the best at that price point.
Author:  Mike OMelia [ Sun Jul 26, 2015 1:19 pm ]
Used to love the Bosch Colt, now I use the Dewalt on my binding jig. Still have a few colts. I think if you will compare the collet depth (colt) to the DeWalt, you will get an idea of what bothers me. The new Dewalt 611 has led lighted work area, and great depth control. You can also get a plunge base for it. I have that bigger Bosch mentioned above with plunge for doing neck stuff. I have a colt in a Bishop Cocheran jig... love that for rosettes. I don't worry too much about collet depth there since I use small bits. Plus I have a Precise Bits collet on it. Gonna get one of those for the dewalt.
Author:  ernie [ Tue Jul 28, 2015 8:24 am ]
For those on a budget, CL can be a source for used lam routers , listen for the squeal of a worn out bearing . I picked up a used PC 7310 lam kit . with all the sub bases, bearing guides, bells /whistles, rtr bits etc for$60. last niight.
