It is currently Wed Aug 20, 2025 9:20 am
PostPosted: Tue Jul 21, 2015 8:32 pm
I used StewMac's clear waterbase grain filler on this batch of 3 guitars. 3 applications/sanding of grain filler and it did not do the job. (Now on coat 38 of Target EM6000. Please don't hurt yourself laughing.) I really like the concept of a clear grain filler and want this to work.
Questions:
1. Is there anything wrong with putting a coat of sanding sealer down first before applying the grain filler>
2. What about adding SystemThree Silica Thickener to the grain filler to help fill the pores.
VOCly yours,
Bill
Formerly know as Mandodiddle.
PostPosted: Tue Jul 21, 2015 9:50 pm
First name: Greg
Last Name: B
City: Los Angeles
Are you talking about regular sanding sealer or some new water based type?
Sanding sealer is meant to provide a quick surface buildup for use under lacquer top coats for use in production furniture (etc). It's not actually meant to fill pores. Typically a couple coats are applied over bare or stained wood, sanded flat, and followed by a couple thin coats of lacquer off the gun. This is meant to save time and materials, and is a lower standard of finish than is expected in guitarmaking.
As to you question #1, I'd worry about adhesion issues, since it is basically soap dissolved in lacquer. You could always try it on scrap.
AFA #2, I guess you will have to try it.
Let us know how it works. I think a lot of people would like to have an alternative to epoxy that is clear.
PostPosted: Wed Jul 22, 2015 7:35 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I typically put sealer down before and after the pore filler.
Brian
PostPosted: Wed Jul 22, 2015 8:11 am
I did a lot of experimenting with the clear water borne grain fillers --- not for me. But one thing I found that greatly improved the results was to more or less "water proof" the surfaces with a solvent based sealer which actually take a couple of coats. That said, no matter what type of pore filler I use the first step is to seal the wood to trap the oils and resin.
I am not a fan of sanding sealer since it is by design a very soft coating so it can be removed/sanded easily -- I am not sure this is a good idea under some top coat products? I use a vinyl sealer.
Brian H. does finishing for a living so I'd say he offers some really sound advice and its great that he shares his expertise.
Ken Cierp
PostPosted: Wed Jul 22, 2015 8:13 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
I spray vinyl sealer x 2 before pore filling, then sand, then one more sealer. This is over pigmented filler but it gives great results.
It will probably be alright.
